Help me! Volume dip when processing Audiosuite plug-in\'s
hello everyone.
I am running OS 10.3.9 on a G4 and i am running pro tools LE 6.9. I have had this issue for awhile now that I am just now trying to rectify. As I have an older computer, processing power is sometimes in short supply. Often times, during a session, I will decide to process some of the plug-in's I have been using in order to free up some CPU space. I usually will start by processing my EQ's. When I attempt to process plug ins, I find that the newly processed track has a very drastic volume dip from before I processed it. As I process with the exact same settings I was using when I had the plug in as an insert, why would I be getting this big volume drop? Has anyone else experienced this problem who can help me? Off hand, I remember it happening most recently with T-racks EQ, but i am fairly certain it has happened with other plug in's as well. thank you - Erik |
Re: Help me! Volume dip when processing Audiosuite plug-in\'s
Eric,
If you only select a second of the file and Audiosuite-process it, can you see the level drop on the waveform (ie, graphical display)? Roey |
Hey Roey, thank you for responding,
Yes, I can see a change in the graphical wave form when I process the plug in. As I am using an EQ, I would expect some change in the waveform? The wave form is considerably smaller than the original though. The same thing occurred when I tested it on a one second sample. Any idea what could be causing this? - Erik |
Well,
Perhaps you could try the following: Create a new session. Import some audio into a track. Select 3 seconds. Process these 3 second with your EQ via Audiosuite. Don't dial anything on the EQ - just have it neutralized. Does the level still drops? |
AudioSuite plug-ins Processing Problem | quiquedom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2011 02:51 PM |
Issues processing with audiosuite plug-ins | basicrecordings1985 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-14-2008 11:15 AM |
Volume decrease when processing audio with audiosuite | korgscrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-07-2007 01:02 PM |
Help...plug-ins not processing with audiosuite | basktqase | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-08-2005 08:11 PM |
Waves 3.5 is putting 2 of each Plug-In's in RTAS and Audiosuite | TriAxis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-03-2002 04:43 PM |
