Old 10-12-2021, 09:49 PM
Goombot Goombot is offline
Default Writing automation at 2x speed
Is there any way to write automation while ProTools is playing back at faster than normal speed? It doesn’t seem so but is there any other way to do this? I’m looking to use WaveRider or Vocal rider on a long piece of dialogue and I’m wondering if there is any way to speed this up. Elastic audio doesn’t seem to work, switching sample rates doesn’t work, there is no audio suite for that type of thing. Any third party programs or anything?
Old 10-12-2021, 10:21 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Writing automation at 2x speed
I am amazed that someone even came up with this idea (of writing automation non-realtime), but if it is otherwise not possible you can bounce your track as original sampling rate (say, 48k) and then create a new session in double sampling rate (in this example 96k) then importing the track without SRC so it plays back in double speed.
Janne
Old 10-13-2021, 12:55 AM
danyg danyg is offline
do you know that you can transfer the volume automation from Vocal Rider to an automation lane of your DAW and quickly edit it there with the mouse?
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 10-13-2021, 05:09 AM
Sardi Sardi is online now
You could try Waverider TG.
It has an AAX and Audiosuite version so you can process the levelling offline. Very fast.
Old 10-13-2021, 09:40 AM
Right. I have the main version of WaveRider. I didn't know the TG version was an AudioSuite. Still not ideal. Ideally it would be great to process a volume automation lane in non real time but I guess there really isn't anything that will do that.
Old 10-13-2021, 10:09 AM
midnightrambler midnightrambler is online now
I'd use Elastic - set it to ticks, double the tempo, write away, put the tempo back when finished. Don't see why that wouldn't work? Unless the plugins can't cope with the double speed for whatever reason. Would the "Melodyne" trick work, where you put the "Rider" plugin into "write" and then commit the track and then undo? Can't vouch as I've never tried with any other plugin other than Melodyne.
Old 10-13-2021, 10:39 AM
That doesn’t work. Automation doesn’t follow elastic audio.
Old 10-13-2021, 10:56 AM
Of course it does. It would pretty useless if it didn't.
Edit : https://www.youtube.com/watch?v=cFp1ne8blG4
This is a quick vid where the automation is following the elastic exactly. Apologies if I'm misunderstanding.
Old 10-13-2021, 11:00 AM
daeron80 daeron80 is offline
This is not the answer you're looking for, I know that, but... iZotope's RX Leveler module does much the same thing at max processor speed. Hour-long messages in seconds.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 10-13-2021, 11:59 AM
Yes I understand but you still need to write the automation in real time.
Automation not writing Jenre Windows 7 07-02-2014 10:04 AM
Automation writing on it's own cananball Post - Surround - Video 4 06-28-2014 11:36 AM
automation issues (re-writing automation when it shouldn't) revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2008 02:41 PM
Writing Automation jcpro1 Tips & Tricks 1 03-31-2005 05:09 PM
About writing speed! CuiRF Digidesign Hardware & Software 1 05-27-2002 12:49 AM
