Unable to locate hardware at startup
I recently bought a new laptop and ordered a Mbox 2 from germany (I live in Sweden) just to record some music but I can't get it to work!
At first my computer couldn't even read the installation CD for Protools 8LE, it crashed every time! After a lot of reading on the internet I got past the problem with help from a friend and Daemontools. FINALY it worked. But when I'm launching Pro tools I just get the message: "Unable to locate Digidesign hardware. Make sure your hardware is connected and turned on. Click "OK" when the hardware is ready." even though my mbox is connected and the lights are on and everything looks fine. I'm really starting to regret that I purchased a mbox and not something from another company. There seems to be A LOT of problems with pro tools if you judge by what you read on the internet. Please help! I don't have IE8 installed. I'll post a Sandra report as soon as it's finished, it's been on 8% for 15min now |
Re: Unable to locate hardware at startup
When you say 'a lot of problems,' keep in mind that:
a) every software (including Miicrosoft's OS) has 'problems...' b) postings on the internet are usually *only* about problems... you very rarely see posts from people who are not having problems... You need to post a little more about your system for you to get any help here though...
Eddie Sullivan Long Island Mac Tech http://long-island-mac-tech.com [email protected] 631 786 3924 Freelance Mac/Pro Tools tech for hire. Metro New York Area. Last edited by promixr; 11-03-2009 at 10:30 AM. Reason: spelling |
Thanks for the reply.
You're right about the problems. I just wan't it to work properly from the beginning, it's pretty annoying not even beeing able to start the program. Here's the information: "Computer Model : Toshiba Satellite L350D Workgroup : WORKGROUP Host Name : Niklas-dator User : Niklas Processor Model : AMD Athlon(tm) X2 Dual-Core QL-64 Speed : 2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 2x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size Computer Mainboard : Toshiba Portable PC BIOS : Insyde Corp. 1.60 06/04/2009 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DIMM Registered DDR2 Chipset Model : Toshiba RS780 Host Bridge Front Side Bus Speed : 2x 1.3GHz (2.6GHz) Shared Memory : 256MB Memory Bus Speed : 2x 72MHz (144MHz) Chipset Model : AMD F11h Athlon 64/Turion/Sempron HT Hub Front Side Bus Speed : 2x 1.3GHz (2.6GHz) Total Memory : 4GB DIMM Registered DDR2 Memory Bus Speed : 2x 240MHz (480MHz) Memory Module(s) Memory Module : Hynix (Hyundai) HYMP125S64CP8-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Hynix (Hyundai) HYMP125S64CP8-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : ATI Radeon 3100 Graphics (SM4.0, 256MB, PCI) Storage Devices Hitachi HTS543232L9SA00 (320GB, SATA150, 2.5", 5400rpm, NCQ, 7MB Cache) : 298GB (C:) (E:) TSSTcorp CDDVDW TS-L633A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) ETAD AJ0LIFS (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (D:) Logical Storage Devices WinRE : 1GB (NTFS) Vista (C:) : 149GB (NTFS) @ Hitachi HTS543232L9SA00 (320GB, SATA150, 2.5", 5400rpm, NCQ, 7MB Cache) Data (E:) : 148GB (NTFS) @ Hitachi HTS543232L9SA00 (320GB, SATA150, 2.5", 5400rpm, NCQ, 7MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW TS-L633A (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (D:) : N/A @ ETAD AJ0LIFS (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) Peripherals LPC Hub Controller 1 : Toshiba IXP SB600 SMBUS Controller LPC Hub Controller 2 : Toshiba SB700 LPC host controller LPC Legacy Controller 1 : T0 FC-11h Audio Device : Toshiba IXP SB600 High Definition Audio Controller Audio Codec : Realtek Semiconductor 0268h Audio Codec : Lucent/Agere Systems (Was: AT&T MicroElectronics) HDA softmodem Serial Port(s) : 1 Disk Controller : Toshiba SB700 SATA Controller [AHCI mode] Disk Controller : Toshiba SB700 IDE USB Controller 1 : Toshiba SB700 USB OHCI0 Controller USB Controller 2 : Toshiba SB700 USB OHCI1 Controller USB Controller 3 : Toshiba SB700 USB EHCI Controller USB Controller 4 : Toshiba SB700 USB OHCI0 Controller USB Controller 5 : Toshiba SB700 USB OHCI1 Controller USB Controller 6 : Toshiba SB700 USB EHCI Controller SMBus/i2c Controller 1 : ATI SB600 SMBus SMBus/i2c Controller 2 : ATI AFS SMBus Printers and Faxes Printer : Send To Microsoft OneNote Driver (300x300, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Realtek RTL8102E Family PCI-E Fast Ethernet NIC (NDIS 6.0) Wireless Adapter 1 : Atheros AR5007EG Wireless Network Adapter (802.11g (ERP), 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows Vista Home 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 3.6" |
I think Vista Home might be the culprit- here is Digidesign's page on supported configurations for Vista, laptops, and USB audio interfaces:
http://www.digidesign.com/index.cfm?...4&itemid=36860 Here are the guidelines for PT 8.0 and Vista: http://www.digidesign.com/index.cfm?...4&itemid=36858 Your version of Vista Home is Service Pack 2- you may have better luck with Service Pack 3. But your laptop in general is not a tested/supported configuration. You should have consulted this user group *before* you bought your laptop, or consulted the Digidesign dealership, or consulted Digidesign.com. Digidesign has very strict compatibility requirements for their hardware and software and these requirements directly impact stability and performance. You may eventually get things to work on your laptop, especially if you upgrade to SP3, but you may not end up with an optimal experience.
Eddie Sullivan Long Island Mac Tech http://long-island-mac-tech.com [email protected] 631 786 3924 Freelance Mac/Pro Tools tech for hire. Metro New York Area. |
I've read that there's no known issues with Vista home premium 32-bit, even though it's not tested by digidesign.
What I read before purshasing was the system requirements which says: "System Requirements Digidesign-qualified Windows Vista- (32-bit Business or Ultimate), Windows XP- or Mac OS X 10.5-based computer Minimum 1 GB of RAM DVD-ROM or equivalent optical drive for software installation Available USB port for Mbox 2 system (USB hubs not supported" Then there's like a whole novel with text about which hardware is compatible or not but that isn't quit clear if you don't search around a while. I think the requirments should be more specific. I'll check the links you posted and see if it works better. Thanks for the post. |
Any one els that can help in any way?
I really want this to work. |
I haven't seen a lot of success in here with AMD laptops, but not to say that it doesn't happen. Perhaps the drivers didn't install properly? Does the MBox 2 show up in the Device Manager when it's powered up? I don't see it in your Sandra report.
The Mbox2 is recognized by windows and shows up in the system tray and the lights arre on. It's not located by PT at startup though :S
I'll try and reinstall protools and see if it works better. Thx for the reply! |
What physical drive are you installing to? And what drive do you plan to record to? 5400 rpm drives are not recommended for recording and PT should be installed on the C: drive(which you may have done but I was just wondering).
Yes, Albee 1952 has asked a very important question..
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o | MerryD | Pro Tools SE and Essential (Win) | 8 | 08-02-2012 12:59 AM |
Pro Tools Express unable to locate Mbox Mini at startup | Dalyduo | Pro Tools Express on Mac OS X | 4 | 07-25-2012 08:23 AM |
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on.. | qillster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-31-2011 09:08 PM |
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? | pein | Pro Tools M-Powered (Win) | 2 | 10-07-2009 12:01 AM |
ProTools is unable to locate 002 Rack upon startup | IntegInc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-22-2004 07:54 AM |
