No response from tracks when trying to playback or record
Hello,
newbie here working on my first project. I've got a few tracks setup, one I imported from file, plus a couple guitar tracks for each section I'm working on. I was recording and listening back and everything was going smooth until all of a sudden - while working outside the app for a few minutes - the audio in my headphones went dead. You know how there is a sound, even when your not recording or playing back? That went totally mute. All the buttons seem to respond when I click on them (record-enable, play, stop etc.) and the line under the blue arrow in the mix window is blinking. But when I hit play or record - nothing happens. I had to save the project, and close PTF. When I re-opened it I was fine. Any thoughts on why this would happen?
guitarkevin69 Pro Tools | First M-Audio M-Track Solo (USB) Experience Level - newbie HP Elitebook 840 G5 Windows 10 build 1909 RAM - 8GB CPU - Intel Core i5-8250U @ 1.60GHz SSD - 128GB Internal |
Re: No response from tracks when trying to playback or record
Total guess here, but I suspect you lost communication with the interface. How can this happen? I see 2 possible ways:
#1-you did not disable Power Management on all USB ports(aka USB Root Hub in Device Manager). #2-you are allowing Windows to use the interface as the "default playback device". Doing this can prevent Pro Tools from full access to the interface. The best practice for Windows users is to set Windows Sound Properties so that Windows uses the on-board sound card(Realtek?) as the default playback device(which gives Pro Tools total control of the interface). BTW, sometimes a Windows 10 update will reset both these system tweaks back to the setting you DON'T want
Does PT9 use different buffer for playback and record-enabled tracks, like Logic? | yeloop | Pro Tools 9 | 5 | 11-09-2010 04:43 PM |
8.04 Slow Record/Playback Response | JLEpperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-12-2010 01:36 PM |
Loop playback with record enabled MIDI tracks | fm_xtk | Pro Tools TDM Systems (Mac) | 2 | 07-04-2009 01:30 PM |
Can I record audio tracks live while midi playback is on? | wfasano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-08-2009 05:55 AM |
How many Tracks for Record/Playback? | Mystere1 | Pro Tools M-Powered (Mac) | 3 | 11-04-2008 10:45 AM |
