Avid Link credentials issue?
Avid Link is requesting admin credentials for the express/silent plugin update installation, and none of the username password combinations I provide work.
Can anyone point me to where I am supposed to get these from? Avid Link: 2022.5 Edition Windows 11 Pro Version 21H2 Installed on 2/1/2022 OS build 22000.675 Experience Windows Feature Experience Pack 1000.22000.675.0 Edit: Solved. Last edited by MVZE; 05-27-2022 at 04:37 PM. Reason: Added solution. Thanks for the help! |
Re: Avid Link credentials issue?
This should be your computer's user name and password. Your profile says you're on macOS (though you posted to the Windows subforum), so the account from System Preferences > User & Groups (and make sure you check the 'accept' box). Did that not work?
• linkedin •
Apologies, I tried making this post a trillion times and was met with PHP errors.
I can confirm this is on a Windows machine I am putting together for a client. Edition Windows 11 Pro Version 21H2 Installed on 2/1/2022 OS build 22000.675 Experience Windows Feature Experience Pack 1000.22000.675.0 |
Thanks for clarifying.
You have the Admin Functions pref enabled, and you're using their username and password? "You will be required to enter an administrator password to set install options." [pg9 in the Ref Guide]
• linkedin •
There is one user account set up on the machine. The account was created using a Microsoft account on first setup. The computer issues a PIN to log in and out of the user account. As far as we are aware, there has never been a traditional password set on the machine, aside from the 4-digit PIN used to log in.
When the window pops up, it auto fills the user account name (the first 5 letters of the email) but I question whether or not its correct. The user in question is the only account, as such they are also an admin. |
There *has* to be a password on an account to enable use of a Hello PIN. So here likely the Microsoft account password.
Solved. The administrators full email address for the Microsoft account needs to be put in, not just the first 5 characters that show up by default.
Using the full email, and the password for the Microsoft account fixed the problem. Last edited by MVZE; 05-27-2022 at 04:36 PM. |
I am having the same issue. I have had the request before (when updating to 2022.4) and it accepted my Windows email and password. Now I've tried updating via Avid Link and got the ''download failed'' message, so I have updated Avid Link manually. This time it refuses to accept my username and password. I've tried combinations of username and email and they all fail. I have even changed my Microsoft account password - still refuses to accept it.
I am using a local account for my Windows desktop. The Avid Link program is not accepting my local user account to allow the express install. Why?
Satellite link issue | yop22 | Pro Tools | 2 | 03-31-2022 02:00 PM |
Can't link my Avid master account to the Avid community | IuliaC | Licensing & Accounts | 8 | 02-25-2020 05:01 AM |
Avid Application Manager or Avid Link | mojohos | Windows | 2 | 02-12-2020 06:11 AM |
Avid Link: possible ProTools update issue ahead? | dvdr | macOS | 1 | 01-26-2019 09:46 AM |
Venue link issue | digidesigner | VENUE Live Sound Systems | 13 | 07-19-2011 06:44 AM |
