Pro Tools using more CPU as I increase the amount of processors. Please help.
Hey all,
This seemed to have come out of the blue. I am running the current update of Pro Tools. I'm not sure if this started right after the update. My memory is a bit hazy on that one. Older sessions with a decent amount of plugins or sessions with few plugins that take up a lot of CPU will simply not play without the CPU spiking or the audio cracking and popping unless I reduce my processors from using 7 out of 8 to using 2 out of 8. I also did a test on a session using on software instrument and when using 7 out of the 8 processors, it seemed to use at least 10-15% more CPU than when I switched it to using 2 out of the 8 processors. This has never happened before. I tried trashing all of the prefs, the DAE folder etc, but the problem still seems to be there. Anyone experience this before? Any idea how I may go about fixing this? I am using a Hackintsoh, but as I said, everything has always worked great up until now. Thanks. OS X 10.7.5 Pro Tools 10.3.3 3.39 GHz Intel Core i7 16 GB 1333 MHz DDR3 RAM |
Re: Pro Tools using more CPU as I increase the amount of processors. Please help.
Try disabling Hyperthreading in Bios.
I'll try that and report back.
Any idea why I wouldn't have had to do that before and would have to all of a sudden do it now? Thanks. |
This type of behavior is _very_ dependent on the exact plugins and how many of them you are using in a session. Darryl |
I changed literally nothing. I went back to a session that I know ran 100% ok before, simply wanted to re-bounce the song, and thats when I noticed the problem. The same song gave me huge CPU spikes, cracks and pops etc using 7 out of the 8 processors. When I brought it down to 2 out of 8, I was able to bounce the track.
The only thing I can think of that may have changed was updating Pro Tools to the latest update. I've also been using Pro Tools for almost 10 years now, so I am aware of how it should act with how many plugins or with certain plugins. Thanks. |
In this case if its not due to a change in the core Pro Tools you actually probalby also updated some of the plugin code itself. So pretty significant changes. Darryl |
Hmm...
Could bad RAM cause this type of behaviour? I'm currently testing all of my RAM and all of the RAM slots and suspect I may have one bad stick of RAM. Not 100% sure yet, though. |
And have you disabled hyperthreading yet, to help sort out certain possible plug-in issues.
Not that I'm aware of. Although bad RAM can cause all sorts of issues. I'd suspect a problem with a plug denormalizing first.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Darryl |
How do I keep track of the total amount voices I'm using in Pro Tools 10? | paulisdead | Pro Tools 10 | 8 | 05-05-2013 10:09 AM |
Pro Tools Won't Open...Small Amount of Text | mdf31 | macOS | 2 | 03-10-2013 10:11 AM |
Need a small amount of help with P-Tools 7 | RiffWraith | Windows | 3 | 12-06-2011 08:16 AM |
processor amount in pro tools | Mascola24 | Pro Tools TDM Systems (Win) | 4 | 11-02-2009 08:51 AM |
Buffer problems - Increase-Decrease-Increase | 6string | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-17-2005 10:01 AM |
