controlling the bpm on a track
Just needed to know if it is possible to speed up or slow down the bpm on a track in a session to my desired speed. I plan on using this technique aid me in remixing tracks etc.
Thanks in advance |
Re: controlling the bpm on a track
There's a video at the bottom of this blog post about how to do that, you use the "Tempo ruler" and elastic and tick based audio. I'd also suggest watching the elastic audio tutes both on the Digi site and on my blog.
http://brentheber.com/2008/07/22/edi...-the-fast-way/ |
Ok so I watched your video on your blog and I dont think that is what was looking for. I only need to know how to speed or low down a certain track.
Thanks |
If you have PT 7.4 then you can use elastic audio in varispeed mode on just that track. or you can use audio suite/time shift in varispeed mode. Chris
controlling PT track/mix settings with PC keyboard | jurld | Getting Started | 3 | 03-10-2014 04:42 AM |
Trouble controlling the tempo in a click track? | Mike1360 | Windows | 3 | 07-09-2013 07:11 PM |
Controlling multi instrument tracks with single MIDI track? | MotifMan | Virtual Instruments | 10 | 07-21-2012 01:08 PM |
Controlling a drum machine with a MIDI track | j20056 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-27-2002 12:31 AM |
controlling PT via 9 pin | TurboTrim | Tips & Tricks | 0 | 02-08-2000 08:04 AM |
