Quicktime Movie Audio lags on playback in ProTools 8
I am having a problem running a Quicktime movie in ProTools 8 (HD). When I hit the spacebar, there is 1 to 3 second delay before the audio plays back. This occurs even when there is only one stereo audio track. If I take the video offline the audio portion plays back fine.
I have Mac Pro Intel (tower) 2 x 2.66 Dual - Core. Version 10.5.8 with two gigs of memory. The session (with the Quicktime movie) in on an external firewire drive. I am using two Samsung widescreen monitors. I used to do this successfully in PrpTools 7 Amy suggestions? Dennis |
Re: Quicktime Movie Audio lags on playback in ProTools 8
Open the movie in quicktime.
Hit apple j to open the movie properties. Select the the quicktime's audio track and delete. Save over the movie or save as a new one if you want to keep a version of the quicktime with the SOT still in. Import it into Pro Tools Done. It's a quirky bug that started in leopard. When you are hitting play in PT, leaopard is looking for an output to play the quicktime audio which causes the system to pause while it "figures it out". Some people have also had success with changing the audio settings in the system prefs. I've run into situations where prefs changes didn't work, but deleting the audio track from quicktime seems to work every time. Best, Matt |
Got to system preferences/audio/output and make sure that the output is set to internal, Not your digi hardware.
As far as I´m concerned, this is all you have to do, no need to extract audio from the quicktimefile. arvid |
ProTools 8 playback lags behind | banjo71 | Pro Tools M-Powered (Win) | 7 | 11-27-2009 01:39 PM |
Quicktime Movie Audio lags in ProTools 8 | Dennis Scott | Pro Tools TDM Systems (Mac) | 2 | 11-19-2009 09:51 PM |
QuickTime Movie Playback PT7 LE | mickaslin | Post - Surround - Video | 3 | 05-16-2006 05:11 PM |
QuickTime Movie Playback Problem | Chief Technician | Pro Tools TDM Systems (Mac) | 3 | 03-01-2005 11:25 AM |
Best video card for Quicktime movie playback? | hanzoid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-11-2003 07:05 AM |
