Problems with using key input or side chain in 7.0
Has anyone had any issues with using the key input routing on plugs in 7.0? For example, I am using the key input for a side chain into a compressor and it intermittantly gives me lots of noise and distortion. If I disable the key input all is well. This is happening with both the LA-2A Bomb plug and the Slightly Rude Compressor. Never had this issue in 6.
Any thoughts, anyone? |
Re: Problems with using key input or side chain in 7.0
Trying again. Has no one else seen this problem?
Is it possible to side-chain an EQ? | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-03-2009 06:00 PM |
side chain / key input compression | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-03-2009 09:17 AM |
How do I set up a Side Chain | junglelabs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-30-2007 10:49 PM |
Side Chain | ByPass | Tips & Tricks | 1 | 05-08-2007 12:33 PM |
A better way to side chain? | studiojb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-24-2007 04:40 PM |
