Pro-Tools Not Opening
So i came back from a weekend away ready to get to work. So i start up my computer launch Pro-tools and it just bounces up and down then either freezes the computer or just stops bouncing and pro-tools doesn't open. I haven't installed any os upgrades since it worked last (i'm at 10.4.8) running 7.3.1 on a g5. I tried the stuff digi said to do for the 10.4.9 with the prebinding and it said i had no problems. Any idea what happened and how i can fix it?
thanks alot |
Re: Pro-Tools Not Opening
here's the troubleshooting thread and its the first thing to do... http://duc.digidesign.com/showflat.p...fpart=1#177661 trashing the prefs is the usual fix! check all your plugins are up to date and correct! this can often cause problems. Chris
I have tried all of that and trashing the prefs was the first thing i did ... any other suggestions would be great ... i have no system to use as of now
So you've tried a new administrator account and the same thing happened?
You've definately tried everyhing in the troubleshooting thread? Even a re-install of Pro Tools incase the app has become corrupted!! if you havn't tried a re-install, i suggest you do it now. first try the safe un-install option!! when you come to un-install the current version you'll have 2 options? safe and clean un-install, try the safe option first, if that doesn't work try the clean option. un-installer is in the Digi folder in applications or on your install CD or web installer. Let us know how you get on! let us know everything you've done to try and fix the problem!!! then we can suggest what else to try? in may be hardware related?? disconnect everything that is not needed, use just the apple keyboard and mouse and one digi interface, then ad the rest once you're up and running. Chris
Problem Opening Pro Tools 10 Files in Pro Tools 9 | kat768 | macOS | 1 | 10-20-2012 03:57 PM |
Pro Tools 9 asking for iLok authorisation upon opening Pro Tools | jimmycolla | macOS | 0 | 05-13-2012 11:17 PM |
Opening a pro-tools HD session on a windows Pro-Tools LE M-powered system | rhodamorgan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-21-2010 05:31 PM |
Pro tools LE 6.4 not opening | Dr.Marv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-18-2007 10:10 PM |
i need help opening pro tools Please!!!1 | LionHeart1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-13-2006 11:47 AM |
