Re: Save Copy In NOT deleting unused files!
@dodlum: I have the same experience since 7.2.
www.srs-mastering.de Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface. |
I see this problem almost daily. The "select unused" & "remove selected" sequence is definitely broken. It has been a bug (for me) since 7.1
PT 7.3.1 cs4 Mac G5 dual 1.8 10.4.9 |
Nice Paul. Just for reference Command+Shift+U does clear the Undo History Buffer.. so no regions in the undo buffer should remain once you use that command.
Rail
#16
Hold the phone! I might be onto something here.
I think that this problem only comes up with sessions that have used Region Groups. I might be wrong, but I think we should all start looking at that as a possibility. I just did a "final clear out" (as demonstrated in the posted video) on 3 songs. The problem showed up in 1 but not the other 2. I KNOW that the song with the error had Region Groups but the other 2 didn't. Can anyone confirm or refute? |
#17
Hmm. Paul I see this all the time as well. I do use Region groups often so I will try to reproduce when I get a moment.
Simon L. |
#18
Aslo make sure you have "show auto created reigions" turned on before selecting unused
Irl Sanders Music Editor LA, CA, USA |
#19
I just saw this problem for the first time a few days ago, or maybe it was just the first time that I found the problem.
I am running 7.2, but was editing a session that started on a 7.3 rig. Did the correct routine as Rail described, but some unused files got copied over. I did the same routine again, and this time it worked as it should and it didn't copy any unused files (or maaybe just a few). I don't use regions groups.
www.clifnorrell.com |
#20
If it came from someone else, there's always the chance some regions may have been grouped (and then ungrouped) without your knowledge and before delivery to you. |
Deleting unused files? | Danny Winn | Tips & Tricks | 19 | 04-23-2020 08:05 AM |
deleting unused files | anth | Pro Tools 10 | 1 | 03-25-2012 05:05 PM |
deleting unused fade files | der daniel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-17-2009 12:21 PM |
Deleting unused audio files | Beyond The Pale | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-15-2006 09:49 AM |
Deleting unused, lost files, Bug or Me? | flymax | Pro Tools TDM Systems (Mac) | 4 | 03-08-2006 10:29 AM |
