take all plugins in a track offline
hi all, i master in pro tools and have each song on its own track. can i take all the plugs offline (not bypassed completely offline) at once per track? thanks
Re: take all plugins in a track offline
Not exactly what you want, but it may help:
This will toggle (active/inactive) all inserts on all tracks in the same position. Command-Control-click on Mac Control-Start-click on Win Making them inactive does not send audio through them and does not use DSP. |
thanks yeah inactive is what i need but per track. not global slot position but thanks
You can make a track inactive as well:
Command-Control-click(Mac)orControl- Start-click (Windows) the Track Type indicator in the Mix window. To make one or more tracks inactive or active, do one of the following: Select the track and select Track>Make Inactive/Active. Right-click the Track Name in the TracksList, or Mix or Edit windows and choose Make Inactive/Active. |
If you freeze the track, all plugins will become inactive.
If the point is a/b -ing the track with or without plugins you need to put the plugins on aux track and do some routing. Either send via aux or straight to master.
When I master a batch of track in Pro Tools, I tend to treat each track with a complete chain and put SOLO mode in the X-or to quickly compare tracks against each other(and this method also works nicely with 1 or more commercial tracks)
Offline Bouncing with UAD plugins faster now? | DJ Hellfire | Pro Tools 12 | 1 | 06-15-2016 11:24 AM |
offline bounce from Send or Track outputs - track "freeze feature" | OliverH | Pro Tools 11 | 20 | 05-25-2014 04:45 PM |
Offline editor and Waves plugins | monty412 | VENUE Live Sound Systems | 6 | 04-07-2013 11:47 AM |
MIDI IO goes offline when I load certain plugins in PT8... ?!?!?! | ARTHANOR Productions | Pro Tools TDM Systems (Mac) | 5 | 05-16-2009 01:49 PM |
Offline Plugins question | Ken Ferrel | VENUE Live Sound Systems | 5 | 07-30-2008 01:15 PM |
