coreaudiod (Not Responding)
This may be unimportant, but I'm interested.......
I'm seeing coreaudiod (Not Responding) in the activity monitor when the Carbon is connected. Sound still seems to be coming out of the Carbon though..... MacOS 10.15.7, Mac Pro 7.1, 16-core, 48GB RAM. PT is version 2021.6.0. Carbon firmware is 1.0.1.2106111846A Happens whether PT is running or not. Sound plays from PT and from third party apps (browser, Audirvana, QuickTime). |
Re: coreaudiod (Not Responding)
I have a question about your system line ,, how are you determining what your firmware version is ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Ventura 13.2.1 Enjoy the Journey.... Kev... |
If you launch PT, select the Carbon as your interface, and go to Setup -> Hardware, the Firmware version is shown at the bottom left of the dialog box.
Ha I never even noticed it there thanks
https://lukehoward.com/ |
I suspect that this is one of the things that caused overheating of less powerful Macs and got fixed in one of the Big Sur releases, but as you'll see from my post in another thread (https://duc.avid.com/showthread.php?t=414703&page=3) I'm not clear what Avid's advice currently is for MacOS version when running Carbon + 2021.6 Maybe it will end up like the WiFi advice, where you must have WiFi on for iLok cloud, but must have it switched off for optimised performance. Or Spotlight, which you must switch on unless you are doing a recording over 50 minutes, in which case you must switch it off. Having the Carbon connected causes my Mac to consume an extra 30-40 watts of power continuously, even when not playing any sounds, so it's definitely having an impact, it's just covered up by the excellent cooling of the Mac Pro. |
Hi there,
I am running the same OS as you, but on a 2020 MBP, and I am getting this coreaudioid (not responding) constantly with Carbon. Also, every once in a while all the CPUs spike on the System Usage page Pro Tools, when I'm just idle. Did you say this is fixed in Big Sur? My Mac runs much hotter while using Carbon for sure with 10.15.7... Thanks. |
FWIW, just in case it means something to someone; I've learned over the years that processes in Act.Mon. that ends with a "d", usually means "deamon". So to me, it's pretty obvious that this process name is a shortening of "Carbon I/O deamon". Sounds like a pretty essential component, I think. It would probably reside in the "LaunchDaemons" folder in sys/lib. Deamons are launched at startup.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
It may be different on a laptop, I don't know. I can't say I like the look of Big Sur and it feels less snappy than Catalina, but PT performance seems about the same. Try sending a DM to Kyle Splittgerber or Mark Corbin - both from Avid - to see if they can help diagnose and improve your problem. Dominic Last edited by dominicperry; 09-07-2021 at 01:20 AM. |
Coreaudiod errors on startup | hunter_aran | macOS | 1 | 01-09-2013 06:17 AM |
PT 8.0.1 not responding NEED HELP | keytone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 06-15-2010 05:43 PM |
coreaudiod (Not Responding) | Grant@2020sound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-13-2009 08:44 PM |
coreaudiod (not responding) | Ziko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 10-13-2009 09:10 AM |
coreaudiod not responding - PT8 install | Rich Breen | Pro Tools TDM Systems (Mac) | 1 | 02-10-2009 11:59 AM |
