Old 05-06-2011, 10:27 AM
StrokeMyAxe StrokeMyAxe is offline
Default Pro Tools 9.0.2 Update Won't Recognize Oxygen 61 Keyboard Anymore
Hello all,
This is my first post and my first issue I have not been able to solve on my own.
I recently updated PT9 to the newest update and since then my oxygen 61 controller has not been able to communicate correctly ( at all ) with my PT9 System. I get a system pop-up every few seconds and then I have to disable it. I have tried to power cycle it, unpluging it, disabling it and reenabling it.
Has anyone had this same issue? or does anyone have another idea to fix it?
Win7x64
Old 05-06-2011, 07:50 PM
Default Re: Pro Tools 9.0.2 Update Won't Recognize Oxygen 61 Keyboard Anymore
The only thing I can think of is to try it on a different USB port(and double-check that power management is turned off on all your USB ports).
Old 05-06-2011, 08:29 PM
ericsvizeny ericsvizeny is offline
Default
Dumb question...but did you make sure MIDI thru is enabled?
Old 05-07-2011, 03:46 PM
Hmm.. well I never disabled it. In fact, I don't ever remember specifically enabling a "Midi Thru" option. Where might I find this in PT9 to check to see if it's enabled?
Old 05-07-2011, 04:01 PM
Under the OPTIONS menu.
Old 05-08-2011, 12:21 AM
Ludia Ludia is offline
A few days back I experienced something similar, only I have the Axiom Pro61. This was after I had to trash my prefs and databases. When I added the Axiom into the prefs to use as secondary surface control it worked, however the next time I launched PT I got the same message you described.
What worked for me, I suggest you try it, is to reinstall the drivers for your Oxygen.
i7 5820K @ 3.3Ghz, 32Gb, Windows 7 Ulimate 64, 1x M.2 512 SSD, 1x Spinpoint F1 1TB, 2x Spinpoint F3 1TB, ProjectMix IO, Axiom Pro61, PreSonus Monitor Station,SM ProAudio Stage Buddy, KRK VXT6, AKG K271, SE220A, PT 12.4.0, AMT IEP, Omnisphere, Trilian, EWQL CCC, EWQL Spaces, Ministry Of Rock, Gypsy, Fab Four, NI Komplete 9 Ultimate, NI Maschine, ProjectSAM Orchestral Essentials, Waves V9 Musician 1, Morphoder, CL4
Old 05-09-2011, 02:29 PM
Well the the Oxygen 61 does not use any other drivers with Windows 7. It's a PuP. But I will look into it a little further to see if it auto-installed something.
URGENT I can't record in Pro Tools 10 with my Oxygen 61 Keyboard sergiog macOS 5 09-18-2013 02:41 AM
Pro Tools with Windows 7 ??? (Fast Track Pro & Oxygen 49 keyboard) littlemachine Pro Tools M-Powered (Win) 0 04-08-2012 12:50 PM
Pro Tools 9 don't recognize Digi 003 anymore (Mac) Jeremy Just 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-12-2011 11:32 AM
Pro Tools LE 8.0.3 not recognizing M-Audio Oxygen 25 MIDI Keyboard (W/ Sandra Report) SnackBarSounds MIDI 1 01-09-2010 12:52 AM
Pro Tools with maudio oxygen 49 keyboard... ? GAT305 Pro Tools M-Powered (Win) 1 02-07-2007 12:42 PM
