Old 01-08-2010, 10:13 PM
SnackBarSounds SnackBarSounds is offline
Default Pro Tools LE 8.0.3 not recognizing M-Audio Oxygen 25 MIDI Keyboard (W/ Sandra Report)
Pro Tools LE 8.0.3 not recognizing M-Audio Oxygen 25 MIDI Keyboard.
* HP Pavilion a1220n 2.93 Ghz Intel Pentium 4
* Windows XP (SP3)
* M-Box 2
* Pro Tools 8.0.3
* 1.49 GB RAM
* USB Powered Seagate Free Agent 1TB Hard Drive
* I have tried all of the troubleshooters on the M-Audio website. I have updated the Driver for the Oxygen 25. The controller is showing in the Hardware Device Manager. I downloaded the MIDI-OX program and the controller is functioning properly and being recognized by the computer. In Pro Tools, I have the Peripherals setting on M-Audio Keyboard and both In and Out on Oxygen 25.
Computer
Model : HP Pavilion 061 ED904AA-ABA a1220n
Workgroup : WORKGROUP
Host Name : VERSE
User : HP_Owner
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.93GHz
Speed : 3GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 1 Unit(s)
Integrated Data Cache : 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 1MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector
Computer
Mainboard : Asus Goldfish3
BIOS : AMI 3.25 09/06/2005
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 1.5GB DIMM DDR2
Chipset
Model : HP 82915G/GV/GL/P/PL/GL/910GE/GL Grantsdale Host Bridge/DRAM Controller
Front Side Bus Speed : 4x 133MHz (532MHz)
Memory Bus Speed : 2x 200MHz (400MHz)
Video System
Video Adapter : Intel(R) 82915G/GV/910GL Express Chipset Family (8 SP, Integrated Graphics)
Storage Devices
Maxtor 6L200M0 (200GB, SATA150, 3.5", 7200rpm, NCQ, 8MB Cache) : 186GB (C:) (D:)
Generic USB SD Reader (USB) : N/A (F:)
Generic USB CF Reader (USB) : N/A (G:)
Generic USB SM Reader (USB) : N/A (H:)
Generic USB MS Reader (USB) : N/A (I:)
ST31000528AS (1TB, USB/SATA300, 3.5", 7200rpm, NCQ) : 932GB (K:)
TSSTcorpCD/DVDW TS-H552L (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Disk : N/A (J:)
Logical Storage Devices
HP_RECOVERY (D:) : 7GB (FAT32) @ Maxtor 6L200M0 (200GB, SATA150, 3.5", 7200rpm, NCQ, 8MB Cache)
HP_PAVILION (C:) : 179GB (NTFS) @ Maxtor 6L200M0 (200GB, SATA150, 3.5", 7200rpm, NCQ, 8MB Cache)
Optical Drive (E:) : N/A @ TSSTcorpCD/DVDW TS-H552L (ATA33, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (J:) : N/A @ Disk
Removable Drive (F:) : N/A @ Generic USB SD Reader (USB)
Removable Drive (G:) : N/A @ Generic USB CF Reader (USB)
Removable Drive (H:) : N/A @ Generic USB SM Reader (USB)
Removable Drive (I:) : N/A @ Generic USB MS Reader (USB)
Verse HD (K:) : 932GB (NTFS) @ ST31000528AS (1TB, USB/SATA300, 3.5", 7200rpm, NCQ)
Peripherals
LPC Hub Controller 1 : HP 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge
LPC Legacy Controller 1 : SMSC DME1737
Audio Device : HP PufferM-UL8E
Audio Codec : Realtek Semiconductor 880 High Definition Audio
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : HP 82801FB (ICH6) Ultra ATA Storage Controller
Disk Controller : HP 82801FB (ICH6) SATA Controller
USB Controller 1 : HP 82801FB (ICH6) USB UHCI Controller 1
USB Controller 2 : HP 82801FB (ICH6) USB UHCI Controller 2
USB Controller 3 : HP 82801FB (ICH6) USB UHCI Controller 3
USB Controller 4 : HP 82801FB (ICH6) USB UHCI Controller 4
USB Controller 5 : HP 82801FB (ICH6) USB 2.0 EHCI Controller
FireWire/1394 Controller 1 : HP VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Old 01-09-2010, 12:52 AM
Default Re: Pro Tools LE 8.0.3 not recognizing M-Audio Oxygen 25 MIDI Keyboard (W/ Sandra Rep
**UPDATE**
I have found the problem I was having.
I guess in the new Pro Tools 8.0.3 you now have to have the Record button enabled to hear any sound coming from that channel on an Instrument track. I have never had to have the Record button enabled to enable MIDI before, so this is different, lol.
It's as simple as that.
I hope this may help someone else.
Pro Tools Not Recognizing MIDI Keyboard RNBTee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-29-2011 02:38 PM
Pro Tools Not Recognizing MIDI Keyboard RNBTee General Discussion 0 03-27-2011 06:04 PM
Audio recording out of sync - Sandra Report Elnico50 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-28-2010 01:41 AM
Random MIDI OUT problems on Rack 003 PT8 XP - SANDRA Report Included dogstarism 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-14-2010 06:04 PM
clicks and cracks in audio when i record- sandra report incl Blaztphemer Pro Tools M-Powered (Win) 9 06-17-2008 11:08 AM
