fade file default location
I am working on a large complex project with many sessions on several firewire drives. Suddenly every time I launch a session PT can not find the fades and after the "skip all fades" command has completed it has created a new fade files folder for each session I open. These are created on a different (internal IDE) drive that contains nothing from this project. This isn't in itself a problem except that I like to keep everything together and can't seem to find anything in the manual about how to set a default fade file location, or how to change it. It is probably something obvious but I am in a big rush. Thanks in advance for your speedy response,
Shaun Pro Tools 24 Mix Plus, PT 5.1.1/MacOS 9.2/G4 800Mhz, 512mb RAM, various firewire, SCSI, and IDE drives
I Keep A Vigil In A Wilderness of Mirrors (Fish) |
Re: fade file default location
Shuan,
Were the sessions originally created from a template session located on the internal drive? If the session template was saved to the internal drive then the default disk allocation may have been set to that drive. When creating a new session from a template check the disk allocation before recording. -go to Setups > Disk Allocation and make sure all tracks are going to the correct hard drive on your system. Mike |
Thanks. Neither set of sessions on 2 fw drives were created from a template but tracks from a session on the new "fade" drive were imported to my working fw drives. Probably the track allocation settings on those tracks (even though they contained no audio) say internal IDE, so PT put all new fades there. As to why this just started happening: I have not done any fades on any of the sessions in question until yesterday, which is when the problem cropped up.
Shaun
The fades for a track are created dependent on the disk allocation you've set for the track in question. By changing disk allocation, you change where the fades are created.
Rail
where is the User library default location | bear0328 | Pro Tools 11 | 4 | 05-01-2014 01:19 PM |
setting a default location for bounced files? | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-28-2009 02:44 PM |
default folder location | pauldub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-06-2008 09:14 AM |
Default Fade | Peterjk | Pro Tools TDM Systems (Mac) | 1 | 02-07-2005 08:46 AM |
Select default location for "Open Session" in PT? | GemSmith | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-09-2004 10:34 AM |
