MIDI out...
This is a general question regarding the use of PT MIDI with (non-virtual) keyboard synthesizers. I have Nord Wave and would like to use it in a similar way to using the PT's native Xpand2 or Structure...I'm not interested in playing the Wave synthesizer and recording MIDI data/audio, but instead writing MIDI data in PT's MIDI editor (with the pencil tool) and then get the sounds from the Wave (as well as sending pitch bend and sustain values) I've never done something like that before but I have a feeling it's possible (1) What would be the configuration? Do I need both IN and OUT cable, or just OUT from Pro tools to In in Wave? (2) How do I actually record the sound from the Wave? Do I need audio cables from the Wave to Pro tools as well? I mean, MIDI cables do not carry audio signals, right? I guess I'm not sure how does MIDI exactly work in this case. Thanks a lot! ysound |
Re: MIDI out...
OK...MIDI out from audio interface to MIDI in Synth. then audio cable from synth back to audio interface...
Re: MIDI out...
Almost. Actually, my Audio Interface doesn´t have a MIDI out, if yours does, it´s probably an audio and a MIDI Interface. However Midi out from the Midi Interface to the synth is just fine and audio out of the Synths Audio output into the input of the Audio Interface. Then create an instrument track on which you can control both midi and audio of your synth.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
Re: MIDI out...
Hi mhmh,
thanks! Now I'm trying to understand how many tracks can I use to control my synth using MIDI. I mean, MIDI has 16 channels, right? So is it possible to get 16 different sounds from my synth? (i.e. 16 instrument tracks- each configure to a different channel - and 16 audio channel...no, 1 stereo audio channel for them all??? |
Re: MIDI out...
Re: MIDI out...
OK, thanks!
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
USB midi vs. din midi-(the old style midi connector) | Ling | Pro Tools M-Powered (Win) | 1 | 02-19-2009 02:15 PM |
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-02-2009 12:52 PM |
