MIDI cable
1) Does the Eleven Rack have real 5-pin MIDI connections or just 5-pin with 3 active MIDI connections?
2) Using a Voodoo Labs Ground Control Pro - which cable (e.g., Brand and type) to use? 3) Could connecting a 5-Pin ACTIVE MIDI cable to an Eleven Rack cause malfunction or damage to the 11R? Where did you purchase (Online) your MIDI cable from? (I am working in Shanghai, China - so I have to purchase online gear) (PLEASE do not add different MIDI controllers to these questions) |
Re: MIDI cable
copy and paste from the manual
1)The MIDI In and MIDI Out ports are standard 5-pin MIDI ports, each providing 16 channels of MIDI input or output. These ports can interface with a variety of MIDI devices.
Self Built PC: Core i5 3570K @3.4 Ghz | Asus P8Z77-V LK 8 Gigs Corsair XMS 1600 | XFX HD4870 120GB OCZ Agility 3, 2 TB WD Green Windows 7 Home Premium 64bit Pro Tools 8.0.5 M-Audio Keyrig 49 Eleven Rack w/ERXP FCB1010 | Mackie SRM450v2 | Taylor 314ce | Ibanez RG321MH | ESP Horizon NT-II DSBS |
Re: MIDI cable
Musicians Friend or Sweetwater...or if you get over to Hong Kong they used have good stores (back in 1978) when I lived there...
Re: MIDI cable
Okay, no matter which MIDI phantom power-capable foot controller you have (be it the GC Pro, Rocktron, Bradshaw, Mario's stuff or any other that uses a real MIDI cable), they are designed so that power comes DOWN from a device providing power, TO the pedal, on the unused pins. Mario's and the GC Pro use 5 pin, where the Rocktron and Bradshaw stuff still use the older 7-pin standard.
However, if you plug an adapter directly into the pedal itself, I don't believe that it mults that voltage to those unused pins. Meaning, it shouldn't be sending voltage back up to the 11R from the pedal. I'll have to see if I can find out for sure - I don't know because I built a box for myself that powers the GC Pro remotely from the 11R rack, and thus those hot pins never reach the 11R in the first place. Anything else I have that I plug the GC Pro or the MIDImate into phantom powers them (either my Bradshaw rig or my Mario switcher). I'll see if I can find out for you, but I don't think it's a big deal. I have a bunch of old Tascam MIDI cables that are fully pinned that I use for gigging with phantom power (you have to love old Tascam cabling - they followed a spec, boy S..
"it's not about making the changes, it's about playing ideas in time" Scofield... |
Re: MIDI cable
Are you saying your 11R powers the GC Pro right from the midi cable? I'd love this feature. I currently either have to power the pedal with the A/C adapater or have it powered by using my GCX audio switcher. It powers the GC Pro via midi but I really don't need the GCX with the 11R but have to keep it in my loop to power the GC Pro (i don't have a separate a/c adapter )
PRS CE22, Parker Dragonfly - Dutkiewicz, Martin 000CXE Eleven Rack, Axiom 61, Ground Control Pro |
Re: MIDI cable
I don't know if this will work for you or not, but take a lok at this setup-
http://www.rocktron.com/products/acc...icable5to7pin/ |
Re: MIDI cable
Re: MIDI cable
I have 11R with GC Pro, but the adapter is for 120V and we have 230V in Norway. |
Re: MIDI cable
fixed it, I found it in this thread:
http://www.voodoolab.com/forum/viewt...om+power#p2618 |
Re: MIDI cable
Answered here with pics:
http://duc.digidesign.com/showthread.php?t=283465 Only the three normal pins go to the 11R. The power adapter only goes to the other two unused pins on the jack going to the GC Pro, and all 5 pins are connected to the GC Pro via a fully-pinned MIDI cable. Thus, the voltage from the adapter never touches the 11R side of the little box. Make sense? By the way Jerry, the GC Pro MIDI Out is 7-pin, but accepts both 5-pin and 7-pin phantom power coming into it - pretty much anything you throw at it should work. The 5-to-7-pin adapters were originally created to allow 7-pin Rocktron and Bradshaw controllers to work with the newer 5-pin phantom power spec the newer guys were moving to, not the other way around. Hope that helps... S..
WTB:MIDI Splitter Cable. | yamahadrums | Buy & Sell | 0 | 12-24-2012 04:51 AM |
usb-midi cable | sebastiein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-17-2011 09:15 AM |
USB to MIDI cable trouble | Darkostica | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-23-2010 01:04 PM |
midi cable question | tantejo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2002 09:17 AM |
How long can a MIDI cable be? | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-28-2001 04:29 PM |
