Using a Digi002 as audio input device?
Is there a way to setup my Digi002 to use an an audio input device so I can us it outside ProTools just so I can play along with an MP3 or iTunes?
PTLE8, G5, 10.5.5, 6 Gigs ram Thanks, D. |
Re: Using a Digi002 as audio input device?
there should be no problem. Hook it up, go to the system preferences -> audio and then click the tabs "input" and "output" and select the 002 there as the device of choice. cheers, thurston |
Hmmm. . . . I tried that but didn't get any signal.
002 or 002R?
BTW this doesn't work on Windows and I'm not sure about Macs.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
Digi 002 Rack with a Mac G5 & PTLE8
When I select the digi002 in the sound system prefs I get the following messages:
The selected device has no output controls. The selected device has no input controls. |
Go here and download LineIn
http://www.rogueamoeba.com/freebies/ I had to futz around with the core audio driver a bit to get to work, but it did.. In sound preferences, select the 002 as the default output. You may have to launch the core audio driver first to have it show up in the drop down. At this point you should be able to play itunes through the 002. Then, launch LineIn, select the 002 for the input and the output and click on pass thru..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Hm, strange...it worked without problems on my G4 with Digi001 and works without problems on my G5 with M-Box 2...
Hope the other users can provide a solution.. |
MIDI Setup - Not seeing USB Audio Device as an Input Port Option | oldtracy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-15-2013 09:22 PM |
REQ: Suggestions for Audio Input Device PT9 & MacOS X | lovesexy88 | macOS | 4 | 12-20-2012 04:30 AM |
Rename Midi input devices: USB Audio Device (4)[Emulated] - ugh! | Herkimer | MIDI | 1 | 03-23-2009 03:49 PM |
can't select the mbox as an audio input device | Markus Mehlau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-07-2007 07:59 AM |
AUDIO INPUT Feedback DIGI002 HELP need quick fix | stinkychinky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-29-2005 04:03 PM |
