Old 11-23-2005, 11:32 PM
tikboy tikboy is offline
Default Dual Monitors Setup
I've just installed a second monitor on our system.
I want to find out if there's a setting in PTLE 6.4 that I need to tweak.
what im doing now is manually stretching the window so I can spread my desktop to second monitor.
Is that the only way how to do that. Is there a special setting for a dual display?
I was thinking something llike in Avid when you click maximize button, it automatically fill both monitors.
Any help will be appreciated.
Thank you.
Old 11-24-2005, 06:57 AM
Mike Glenn Mike Glenn is offline
Default Re: Dual Monitors Setup
You are doing it the correct way. There is no special setting for dual display. The next time you start PTLE it will remember the display setup.
Old 11-24-2005, 12:38 PM
bryanbassett bryanbassett is offline
I'm thinking of going two monitors..what video card are you using?
bb
Macbook Pro Intel dual 2.4 OSX 10.7.5 Lion PT 9.0.6 Mbox Mini / 003R
MAC G5 PPC OSX 10.4.9 / PT 7.3 HD2 - I/O 192 /Control 24
DELL Dual Core, MBOX/003R PT 8 WIN XP
Old 11-24-2005, 01:15 PM
K.B. K.B. is offline
Virtually all video cards these days will give you dual output (check your display properties - if you see two with one grayed out, you're in luck). Often the second one is (if memory serves me well) a DVI out, so you need an adapter. But then most cards come with one...
These days for PT my guess is virtually any card will do, but check the compatability stuff up in Allen Halleda's thread above.
For video post work you'll need to be more careful. But there's a lot to choose from. On my main machine I use a matrox P750 which gives triple output - in my config 2 Computer monitors + 1 video. But I have to use Quicktime 6.3 to get it to work properly. On this machine I have a Radeon 7000 running dual monitor. Plays multi-player Quake III Arena in hi-res too...
Got my dual computer monitors setup! 22" x 2. DJ Hellfire General Discussion 6 03-20-2010 04:27 AM
How to setup seperate Mix and Edit windows on Dual Monitors G.roots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-03-2007 08:11 PM
Setup Pro Tools with Dual Monitors (Edit View, Mix rcourell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-16-2005 06:05 AM
Dual monitors mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-15-2002 09:14 AM
dual monitors on G3 Charles Deenen Tips & Tricks 3 04-25-2000 12:58 AM
