Old 10-07-2003, 11:09 PM
gg gg is offline
Default Memory Usage
Hello All,
Is there a way to tell PTLE to use more RAM? Even when running a Davec test my memory usage never exceeds 53%. I have half a gig available - would it not be advantageous to use more of it? I've got a fast processor but I can't get past 29 tracks with 6.1 on my 002.
Mobo: Intel D850EMV2
Proc: P4 2.53 Meg
Bus: 533
Ram: 512 Meg
Video: MSI FX5600 (256 Meg)
Drive: LaCie 80 Gig
Thanks,
gg
D950 3400 Mhz
Ram 3072 Mb
Digi 002
Old 10-07-2003, 11:50 PM
Default Re: Memory Usage
About the only thing I can think of which increases your memory usage is DAE Playback Buffer. But I don't expect it will increase your track count. PTLE just doesn't need that much RAM.
Quad 2.5 G5, 4.5G RAM
Old 10-10-2003, 11:38 PM
gg gg is offline
Tele Player,
Thanks for the reply.
In view of your response then I guess there is no benefit at all to having more than a half gig of Ram in a Protools system. Can anyone suggest any reason for expanding beyond that?
Thanks,
Gary
D950 3400 Mhz
Ram 3072 Mb
Digi 002
Old 10-11-2003, 12:20 AM
Memory is dynamically allocated in Windows and OS X.. the more regions you have and the more overviews which are kept in memory.. the more RAM is allocated. I recently edited a live show which was 32 tracks and continuous regions for over an hour which required a huge amount of RAM (about 800 megs).. generally I believe the overview is the number of samples for the region divided by 256 for each region in the session... each value uses 4 bytes. The more undos you have in your prefs also ups the amount of RAM Pro Tools requires.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-11-2003, 01:39 AM
Calvin Calvin is offline
Also you will use a lot more ram if you are using a sequencing pluggin such as the DR-008, or Battery. These pluggins load entire sound sets into ram so that they can be accessed as quickly as possible.
Calvin
RAM memory usage in PT9 / MAC OS Eekay macOS 45 01-20-2011 06:39 PM
64-bit memory usage Ben Hunt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-07-2010 03:29 PM
memory usage? headphono Pro Tools M-Powered (Win) 4 03-07-2008 06:03 PM
Why does memory usage go up every second? brianjanthony Pro Tools TDM Systems (Mac) 11 11-07-2006 09:07 AM
memory and cpu usage gargoyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-13-2001 02:30 PM
