Old 05-24-2021, 06:19 PM
kmack kmack is offline
Default Plug-in mapping
Does plug-in mapping within Pro Tools work with M-audio keyboard devices or just HUI devices?
Thanks in advance.
Old 05-25-2021, 04:56 AM
Default Re: Plug-in mapping
Thanks in advance.
It should. Depends mostly on the plugin whether mapping works at all. Not every plugin does MIDI learn.
Jack
QAPLA!
Old 05-25-2021, 06:12 AM
Thanks. But what about using the custom mapping that is built into Pro Tools?
Midi learn does works fine for me if a plugin has it's own param mapping options but what about the parameter mapping window built into Pro Tools that sits atop the plugin window? I am currently able to select parameters from this list, but the knobs on my M-Audio keyboard device are not recognized using this learn function even though they work for other instances. Is it possible that the built-in mapping functions can only be assigned to specific slots?
Old 05-25-2021, 07:52 AM
cqd cqd is offline
I'm convinced this used be way better a few years ago..
Old 05-25-2021, 11:20 AM
The only parameter mapping I use in PT other than a plugins' MIDI learn is to map a plugin parameter to an automation lane. I don't have or use a controller for parameters.
Jack
QAPLA!
Old 05-26-2021, 07:06 PM
Can anyone confirm if plug-in mapping using the Pro tools feature works for them at all with any plug-in and any device?
For clarity, I've attached a pic of what I'm talking about.
Plug-in mapping via XML file Postman Avid S4/S6 10 06-03-2015 06:22 PM
plug in mapping uad el fatso sr somastudios ICON & C|24 2 08-30-2011 01:58 AM
Help With Plug-In Midi Mapping Keith Moore Pro Tools TDM Systems (Mac) 2 08-03-2011 04:51 AM
procontrol plug-in mapping roykamen ProControl, Control|24, Command|8 2 02-22-2002 03:36 PM
