Old 10-11-2012, 03:36 AM
Rawer Rawer is offline
Default Mute and fader issue since 10.3.1
So since I upgraded to 10.3.1, If I mute a track, then press play, it will automatically unmute on its own, and more of a problem, if I low a fader down, it will go back up on his own, help please, everything were fine before I upgraded!
Old 10-11-2012, 06:18 AM
akkumusic akkumusic is offline
Default Re: Mute and fader issue since 10.3.1
i have the same problem. There is already written automation on your tracks, which you have to delete.
Old 10-11-2012, 06:19 AM
Just found the solution.
http://avid.force.com/pkb/articles/t...ng/PTSW-173028
Old 10-11-2012, 10:20 AM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
You can test this by putting the track in automation OFF mode and nothing should change,ie. mute or fader level.
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 02:59 PM
fader mute permanently gutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-19-2006 01:35 AM
Fader Mute Function on 002?? Sonic Nomad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-28-2005 10:30 PM
Trim, mute or fader? blues4u Tips & Tricks 3 03-18-2003 01:01 AM
fader pack mute screwy CHRIS AIKEN ProControl, Control|24, Command|8 17 01-24-2003 08:32 PM
