Old 10-24-2008, 12:33 PM
nilsk nilsk is offline
Default How to 'group' automation points?
I made a vocal mix including some
automatic volume fades.
Now I'd like to pull the whole track
down a little ...
But I don't want to fade down every
single automation point separately.
(And I'd like to *not* use a seperate bus,
just to adjust the volume of this track ).
=> How to adjust more than one of the
automation points?
Is there a possibility to 'group' these
points or make more than one active?
Best
Nils
Old 10-24-2008, 12:47 PM
Phil Ogden Phil Ogden is offline
Default Re: How to 'group' automation points?
Highlight all the relevant regions and then use the trim tool.
http://www.myspace.com/philogg
Old 10-24-2008, 04:31 PM
There are actually a few ways to make this kind of adjustment. 1-zoom out so the entire song shows in the edit window, select VOLUME to be shown in the track(as you probably already have up) and grab the volume line after the end of the song and drag it up/down(hold the Ctrl key for fine adjustment). 2-open one of the tracks plugins(assuming it has some) and adjust level within a plugin(almost any EQ plugin will have an output level). 3-insert the trim plugin and adjust there(will act the same as #2).
Old 11-06-2008, 01:36 PM
Thanks for the help!! :)
Best
Nils
Phantom Automation Points...arg! kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-25-2013 05:20 PM
moving automation points pinnacle macOS 3 08-05-2013 02:36 AM
PT 8 Automation Break Points myke2242 Post - Surround - Video 7 04-20-2009 11:17 PM
Automation points resolution ishur Pro Tools TDM Systems (Mac) 3 09-17-2006 03:30 PM
Keep losing automation points DEXTERITY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-18-2005 06:05 PM
