Old 08-16-2005, 04:31 PM
DEXTERITY DEXTERITY is offline
Default Keep losing automation points
I was wondering if someone could please help me. I am using a dual 2.0 G5 with LE 6.7. I am trying to automate a 75 minute mix and for some reason my automation keeps changing on its own. For example, I will have a certain part of a track muted until the next track comes in but the mute points keep changing. I will write the automation so maybe minutes 1:00 - 1:30 should be muted on track one, then start to play at 1:30. however, the entire track is staying muted, it doesn't remember when to "unmute".
if I go back and check the automation after recording it, it plays correctly. But if I save and start from the top the entire track is staying muted. I hope that makes sense. Everytime I fix it, it does the same thing all over again. Any suggestions?
Also, if I record my automation then edit my mix, such as move tracks around do I lose my automation for those tracks? This isn't what happened in this case, but I was wondering because I need to delete something and bring everything forward by a few minutes but was wondering if I will lose my auto. thanks in advance.
Old 08-17-2005, 12:23 PM
DigiTechSupt's Avatar
Default Re: Keep losing automation points
Is this problem happening in this session or all sessions?
I would first start by trashing preferences - if that doesn't work it could possibly be session corruption - try using 'Import Session Data' and import all the tracks into a new session.
Avid Audio Tech Support
Support FAQ
Old 08-17-2005, 04:09 PM
Thank you for your response. It has been happening the past few projects I have worked on. Should I try trashing the preferences? I assume I can find the correct way to do that under the answerbase?
Thanks again for your help.
Is there anything in particular that would corrupt a session?
Old 08-18-2005, 10:40 AM
You can find info on trashing preferences in the 'Setup and General Troubleshooting' sticky at the top of this forum.
There's usually no 'typical' reason a session corrupts - possibly a drive read or write error or maybe a bit of data being read or written to RAM incorrectly.
Support FAQ
Old 08-18-2005, 06:05 PM
Thank you very much for your time and help.
Phantom Automation Points...arg! kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-25-2013 05:20 PM
PT 10.3.4 is creating automation points. Rickaudio macOS 7 04-03-2013 02:31 PM
PT 8 Automation Break Points myke2242 Post - Surround - Video 7 04-20-2009 11:17 PM
Automation points resolution ishur Pro Tools TDM Systems (Mac) 3 09-17-2006 03:30 PM
random automation points ... JEdmunds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-01-2002 11:53 PM
