Old 10-13-2005, 09:10 AM
Glenn75 Glenn75 is offline
Default 192 and 888 system: Do I need a clock?
I am think about buying an 888 to run alongside my 192 for mixing duties. The 888 will provide 8 extra outs so I can mix 16 channels of analog through my desk.
Should I consider an external clock to sync the 192 and 888 together, or should I just use the clock from the 192? What kind of differences should I expect?
Old 10-13-2005, 09:43 AM
Andre Knecht Andre Knecht is offline
Default Re: 192 and 888 system: Do I need a clock?
You won’t need an external clock. Save the money for a second 192 I/O, down the road. The main differences will be the coming from the different sound of the converters.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 10-13-2005, 05:46 PM
Monte McGuire Monte McGuire is offline
Sorry if it's obvious, but you want to get the 888|24, and not just an 888. The old 888 not only sounded awful, but it won't work with an HD system. The 888|24 will work on the legacy port (actually, two of them will with a 'Y' cable) but they don't sound very good, especially the DACs.
Why not get an extra card for your 192 to add 8 modern DACs?? They'll surely sound better than an 888|24! Or how about a lightpipe DAC to attach to your 192?
Best of luck,
-monte-
Old 10-17-2005, 02:02 AM
Best of luck,
-monte-
Thank you for the advice. I was considering the 888|24 because the cost is much lower for me at the moment and until I get enough jobs under my belt to pay for another 192, the 888 route seems to make more sense economically. I have my 192 loaded with 16 analog inputs, so I can't fit the optional 8 DAC card in unfortunately.
I can use the lightpipe to send audio to an external dac if it would sound better than the 888|24. Would it? If so, are there any decent convertors for under a grand?
need help connect master clock to tdm system musicmixer04 Pro Tools TDM Systems (Mac) 1 12-28-2011 12:12 PM
Clock issue in cue system .Popping sol_daddy Pro Tools TDM Systems (Mac) 0 02-25-2011 04:00 PM
OT: Forum clock vs. system clock Media Man Pro Tools TDM Systems (Mac) 2 04-23-2009 10:40 PM
Word Clock Connections in HD3 system AVL SYSTEMS Pro Tools TDM Systems (Mac) 0 05-11-2006 12:04 PM
HD vs Mix system with good clock & verters Sjoko Pro Tools TDM Systems (Mac) 10 05-20-2002 05:37 AM
