Determining ProTools cs Version??
Probably an easy one. Is there a way to tell which cs is installed? I am running 6.9 and have found no way of seeing what the actual version # I am running (except for the initial boot which shows 6.9, but nothing after that). Help/about does nothing for me.
Re: Determining ProTools cs Version??
Browse your hard drive for the program's executable: ProToolsLE.exe (Should be in the C:\Program files\Digidesign\Pro Tools directory). Right click it and select "properties" and then click the "version" tab. If you select comments in the "Item Name" window, the value sindow should show the cs version. The initial release of 6.9 doesn't show a cs number there, if I remember correctly. The "File Version" at the top also indicates which version, just not directly by cs number. The file version of the initial release was 6.9.0.106 (I beleive) and the file version of cs3 is 6.9.0.121
Thanks.
Determining what QT to use | Blazetracks | Post - Surround - Video | 2 | 10-13-2012 06:43 AM |
Determining The BPM of a Hip Hop/R&B Track | Rhapsody | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-19-2007 09:58 AM |
Determining tempos | FrothyG | Pro Tools TDM Systems (Mac) | 6 | 05-05-2005 09:40 AM |
determining file sizes | MarkPresti | Pro Tools TDM Systems (Mac) | 2 | 11-20-2004 06:46 AM |
Determining Loop BPM ??? | Lennylaughter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-20-2003 01:39 AM |
