Re: 2022.9 and Waves broken
I have V12-14 and one V11 bundle I'll try out on my Windows system tonight.
Particularly, the V11 bundle.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
I just bit the bullet and updated the plugs i have. Sad part is i could have bought new licenses for cheaper to cover the 2 plugins i actually still use of theirs for cheaper than the update plan... going to start modding my work flow to get away from using them. Too annoying.
No problems here so far with v13.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
V14 is working fine for me on 2022.9.
On second thought, after doing some actual testing it seems the only plug-in I'm having issues with is Reel ADT. Not sure if anyone else has this plug-in and can give it a test. All my other Waves plug-ins appear to be working properly . I tested on Logic, Reaper, and Soundminer and all VST3 & AU versions worked without issue. So it appears to be a PT version issue. I've uninstalled and re-installed and verified that I'm using the most current version.
Except that with Waves, things are not that straight-forward. They only have one plugin code (shared among different platforms), and every host runs a WavesHell wrapper. As you can understand anything can go wrong right there, but a new wrapper version may fix it (and break something else).
Wow, Waves really broke some hearts.
V-14 not supported but working well 5,1 Mac metal Mojave. Ps V8 iLok still works on vintage G5 TDM system
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
I uninstalled all of my Waves stuff. Problem solved.
I have V7 ilok attached to my TDM rig with a security cable. That version of Mercury + Studio Classics works with G5's to Intelsand latest TDM release. All the Waves I will (probably) ever need, and once that rig breaks beyond reasonable fixing cost it is goodbye Waves forever.
Unless they change their policy and support HDX, that is. I made a promise to myself not to re-wup until that happens, but also promise to Waves that I will do it once they start supporting "every major platform" as they advertised. (My A-list of plugins are the ones working on S6L and now that Apple forced the native issue once again, I could not care less which B-list plugins cannot make it into Apple Silicon world. Good riddance, just like Waves.)
AutoTune 8 (8.1.8 and 8.0.4) broken in 2022.9 | anearforgear | Pro Tools | 20 | 01-31-2024 12:06 PM |
Custom Shuttle Lock Speed broken in 2022.5 [PT-290238] | ArchStanton | Pro Tools | 31 | 10-26-2022 10:38 AM |
Duy plugins gui broken in 2022.9 | ejsongs | Pro Tools | 1 | 10-03-2022 12:39 AM |
Looping regions (Audio and MIDI) broken in 2022.6? | XJENSEN | Pro Tools | 3 | 07-12-2022 10:26 AM |
Is the MIDI zoom on the edit window broken in 2022.05 Windows? | snowplaysmusic | Pro Tools | 1 | 06-17-2022 06:44 PM |
