Old 07-26-2010, 11:35 AM
teffi teffi is offline
Default Voices and DSP
I am currently using a protools HD system and would like to learn more about Voices and DSP.
I would like to understand in which cases you may put, for instance, 96 Voices with 6 DSPs instead of using 96 Voices with 3 DSPs.
Old 07-26-2010, 11:51 AM
Craig F Craig F is offline
Default Re: Voices and DSP
3 chips vs. 6 chips:
6 chips will give you more buffer memory for getting files from the drive(s) (more of a problem w/ PATA drives than SATA drives)
3 chips has less buffer and more chips free for other things
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 07-26-2010, 12:01 PM
Thank you for your fast answering.
Does that mean that, if using SATA, using 3 chips or 6 won't make any difference ?
Old 07-26-2010, 12:04 PM
depends on edit density and drive access/fragmentation levels
Thank you,
Craig
Old 07-27-2010, 04:00 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
there was a post here recently, I will paraphrase it from memory - which may not be scientific, but the gist is there.
Older systems used to get PCI bottlenecks so had to split out the DSP more.
More modern drives and computers do not suffer from these limitations, so use the lower chip count per voice - unless you hit problems (which is unlikely).
More chips does not equal "sounds better" (more chips in my experience makes YOU fat - not your sound!)
cheers
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 07-27-2010, 07:31 AM
Thanks for your answers.
I now understand better these fonctions.
HTML code is On
ran out of voices, what is this? srsoundlab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-29-2007 02:37 PM
More voices in this new PT LE 7.0 ??? MMC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 59 09-27-2005 01:19 AM
Voices,Voices,Voices..How to do it!? 002?MBox?HD? TheMadStudent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-07-2005 09:16 AM
G4 PB and 6.x LE. How many voices? tlester 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2004 04:41 PM
64 voices w/HD 2, PT 5.3.1 ? Jonathan Gordon Pro Tools TDM Systems (Mac) 1 10-08-2003 08:18 PM
