Old 08-24-2005, 01:56 AM
Megadave Megadave is offline
Default Problem with voices on pt 5.1
I have a big problem with my protools 5.1 system.
I've always used a powerpc 9600 with a pt TDM system and 2 888 I/O.
My own PCI Cards are: 1 d24, 1 MIX Farm, 2 DSP Farm.
Now i've changed my computer and I bought a PoweMac G4 1GHz.
I've set my system (in the Playback engine) to: d24+mix (64 voices).
With my old computer it worked correctly and I could used all of the 64 voices.
No my system allows me to use just 43 voices.
I need help
Thanks, Dave
Old 08-24-2005, 09:24 AM
DigiTechSupt's Avatar
Default Re: Problem with voices on pt 5.1
Make sure D-24 card is Rev G1 Ser.# DN06851 or higher and DSP farm is AMCC rev QC or higher for PCI 2.1 compliancy with the g4. You should also be able to check system usage to see if all the cards are being recognized.
Most likely one of those cards is not PCI 2.1 compliant and will need to be upgraded. You can contact Digidesign Technical Support for information on how to get that done.
650.731.6100
Avid Audio Tech Support
Support FAQ
Old 09-27-2005, 03:09 AM
I cheked it and all of my cards are recognized in the system usage window.
They're already upgraded to PCI 2.1.
So what can be the problem for the voices?
Thanks a lot
Dave
Voices and DSP teffi Post - Surround - Video 5 07-27-2010 07:31 AM
Voices,Voices,Voices..How to do it!? 002?MBox?HD? TheMadStudent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-07-2005 09:16 AM
# of Voices per DSP Problem SHIRK Pro Tools TDM Systems (Mac) 28 01-14-2005 04:35 PM
More voices on LE with G4??? Hertz Deep 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-14-2004 08:15 AM
Voices? trakbytes Pro Tools TDM Systems (Mac) 1 08-23-2001 05:52 AM
