midi notes won\'t playback
all of a sudden midi notes are not being played back.
I can play and record midi notes and hear them fine but after i record them they do not play back. This applies to instrument tracks and aux tracks. The midi notes are there and you can see the activity in the midi LED but there is no sound. I have tried different plug-ins and different midi channels and updated to PT 7.1 but no luck. Is there a preference file somewhere I can trash? |
Re: midi notes won\'t playback
Aaron Mulqueen - 001 HD Native |
midi thru is selected.
i do hear the first note of midi playback, but that's all i hear. |
crushed
Trash the Prefers and Databases and see what happens. So you hear the first note, no error messages? And your MIDI triggers aren't blackened? What sort of Virtual Instrument are you using? Have a look at the Transport and see if anything looks out of place. MIDI I/O in the Instruments View controls? filosofem
everything appears normal on transport and preferences, trashed databases and prefs, but didn't help.
i hear the first note from anywhere i start in the region, no error messages. notes keep playing just can't hear them. what's odd is if i IMPORT a midi file from a program like live, it plays back fine. it's only the midi notes I have just recorded that won't play back correctly, even though they are all there. I have tried several different plugs (lounge lizard, minimonsta, electrik piano, etc) same results. |
crushed
How odd ...create a new session and import only that MIDI track, assign your Virtual Instrument, selecting the correct channel via the Instruments View controls (MIDI I/O) and record arm the Instrument track, Alt+click the fader, and Alt+K for Input Only Monitoring and see if that will playback. filosofem
crushed
filosofem
still no luck, same results with reason.
trashed database files and preferences, restored permissions to hard drive, stilll no luck
crushed
Not even working with Reason. Sounds strange. filosofem
first MIDI notes not playing when starting playback | levelaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-17-2008 10:10 PM |
MIDI Playback notes cutting out | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-22-2005 09:06 PM |
Help! midi notes on audio playback cancel out..... | jslstrat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-24-2005 01:36 PM |
Black MIDI Notes??and no Playback?? | B-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-19-2003 02:06 PM |
