Old 05-05-2022, 03:58 PM
JoeTools1963's Avatar
JoeTools1963 JoeTools1963 is offline
Default Frames on Video tracks not displayed in 2022.4
I immediately noticed that my video on the video tracks themselves, had disappeared. The region is there and it plays back in the video window, but on the track, there are no actual video frames in the region.
Joe Tools
Re-Recording Mixer/Sound Designer
Nova Scotia Canada
OS Ventura 13.0
Pro Tools Ultimate 2022.12
Mac Studio Max 32GB Ram
OS 10.8.5
Pro Tools HD Accel Version 10.3.8
Mid 2012 Mac Pro 5,1 32GB Ram
Last edited by jeffro; 05-05-2022 at 07:34 PM. Reason: New topic split from VCA Meters thread.
Old 05-05-2022, 04:08 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: VCA Meters Misaligned in PT 2021.10 on Big Sur [PT-279918]
Originally Posted by JoeTools1963 View Post
...I immediately noticed that my video on the video tracks themselves, had disappeared. The region is there and it plays back in the video window, but on the track, there are no actual video frames in the region...
Do you have the video track set to blocks or frames?
linkedin
Old 05-05-2022, 04:24 PM
Frames. I will double check settings.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 05-05-2022, 07:37 PM
jeffro's Avatar
Frames...
Tried here - though I am on macOS 10.15.7 - and the video frames show correctly. If you can't solve this we might want to get a session and short video file from you to test.
linkedin
Old 05-06-2022, 06:05 AM
Default Re: Frames on Video tracks not displayed in 2022.4
In going to System Preferences/Security And Privacy/Privacy/Accessibility and checking the box next to AEServer, it remedied the problem. Hope this makes sense and helps.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 05-06-2022, 06:38 AM
The one thing that has not changed is this…..
When I (Offline) Bounce Mix with Video, if I have multiple clips to bounce on the timeline, if I do not take the video offline and then back online between bounces, it will crash the video engine.
After having run many different tests on this, I can only surmise that there is a memory leak type behavior. It seems that between clips it is failing to purge the previous clip from memory.
It is kind of a pain for those of us that also do a lot of commercial campaign work.
I have reported the problem to Avid several times, with no resolution to follow. Perhaps something to move up the ladder. [mention]jeffro [/mention]
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 05-26-2022, 04:53 AM
New update! After many attempts and fixes, I changed the output to h265. At that point, the offline bounce with video is stable. Not sure why the h264 output was stalling the video engine, as the original files were also h264. That being said, that was the fix. Cheers
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
Old 05-26-2022, 06:25 AM
its2loud its2loud is online now
This has been my experience as well and has been reported to Avid
Old 05-28-2022, 06:17 AM
Took me a while to figure it out. After several calls to tech support, I realized that it was unlikely that I would get any information that I myself am not aware of. More information in here.
Joe Tools
Nova Scotia Canada
OS Ventura 13.0
OS 10.8.5
2022.4.0 Bugging Stalling Video Synch! ViTheVault Pro Tools 5 05-06-2022 08:24 PM
Video sync test - 2022 testing MIKEROPHONICS Post - Surround - Video 2 03-17-2022 09:18 AM
add Timecode to a Video displayed over Black Magic Intensity torpor Pro Tools 2019 2 12-19-2019 04:18 PM
can't import video, does not contain video frames kflanagan Pro Tools 10 2 11-09-2015 08:14 AM
No Video Frames????? mikevarela Post - Surround - Video 5 03-23-2008 11:28 PM
