Transfuser - MidiFile from Drum-Sequence ?
I searched the manual hi and low but couldn't find it: Is it possible to create a midi file from the Drum-Sequence so that I can edit the single notes directly in ProTools and use the single sounds of the Drums-Synthesizer instead ?
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Re: Transfuser - MidiFile from Drum-Sequence ?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Set the drum sequencer to play pads and send your new midi file to Transfuser on the midi channel you have assigned to the drum sequencer. It will now play back as originally. Now you can edit the file as you wish. You could have also done this without exporting the midi by using the same routing procedure. I'm not sure what exactly you mean by "use the single sound." If you just want to trigger a single sound, just use your midi keyboard to find the note to trigger what you want and create your triggering midi that way. If you mean send each pad sound to a separate audio output for tracking, that's another issue. |
great - thx a lot. This was exactly what I was looking for. Could you tell me where this feature is explained in the manual ? Quote:
Thx again
I did look through the Index for MIDI export, but couldn't find anything. I did some google searches on 'Transfuser MIDI Export' and came across the answer. Quote:
It depends whether you want to trigger the drums entirely externally from a MIDI track or instead use external MIDI to trigger the patterns (really, just little MIDI clips) from within the drum sequencer by using the octave of MIDI notes that select one or the other of the 12 patterns. I wasn't clear on whether you wanted to do this to edit the patterns and then reimport them to the drum sequencer or to trigger the pads in the sequencer entirely from an external MIDI track. Both methods have advantages. Triggering MIDI notes entirely/ individually externally means you can have total control of the MIDI across the timeline of your song with easy access to editing. Using external MIDI to trigger the patterns in the drum sequencer means that you can tweak any or all of the 12 patterns with the different parameters, i.e., filter, decay, level, etc., for instant tonal variations of your drums and also save the edited patterns for future use. It's not really an 'either/ or,' but a 'both/ and.' Make your tweaks in the patterns for 12 variations and then drag them one at a time to your clip region and assemble them in your track. Happy sequencing! |
It's just sometimes when I look for a quick loop in Transfuser (or RMX) that I like to grab the MidiPatternSequence and change some notes of it within ProTools so that they "might" fit better than the "preset" MidiSequence to my already existing drumming. Thx again for you explanation - was really helpful
Transfuser: Recording in the Drum Pattern Editor | Mason00 | Virtual Instruments | 0 | 02-12-2010 10:29 AM |
transfuser drum matrix | daslicht | Virtual Instruments | 18 | 10-31-2009 05:38 PM |
Transfuser: triggering drum pads | synthetik42 | Virtual Instruments | 3 | 02-08-2009 08:40 PM |
Transfuser Drum Pad Questions | remute | Virtual Instruments | 1 | 01-27-2009 11:37 AM |
Transfuser: Recording a drum pattern | Robin Henkel | Virtual Instruments | 0 | 11-15-2008 10:43 PM |
