Old 05-30-2021, 01:12 PM
Top Jimmy's Avatar
Default Re: I/O setup help - I SHOULD ALREADY KNOW THIS!
Originally Posted by K Roche View Post
I guess it must be the differences in Interface because in the "Dashboard" drop down if I click Pro Tool > File > "Create New" I don't have a Stereo mix" as a pre configured template ??? but no matter,,, carry on
“Stereo Mix” is one of the I/O settings you can choose when making a new session. “Last Used” will carry over the I/O settings of the session that was open previously.
I show everyone I work with how to make their own personal I/O settings and how to select them every time they start a new session. This prevents the “why are the settings from your session I opened now in my session” questions.
James Cadwallader
Old 05-31-2021, 05:36 AM
K Roche's Avatar
K Roche K Roche is online now
Yes I know about "last used" an how to use it But as Far as "Stereo Mix" being , "one of the I/O settings you can choose when making a new session" . That is my question.
I am not clear on what is meant by your use of term " I/O settings you can choose " in other words how do you get to that selection ? What are the actual steps taken to get to this selection option ? There must be some selection process I am not aware of
As I noted when I want to make a new session I click PT > File > Create New (if I have "Create From Template" unchecked in Dash board I get a blank session and if I click the I/O in "Setup" I simply get the Carbon I/O matrix ? And "Stereo Mix" is not one of the PT preset templates that show in the various Dash board template selections ??????????????????????
System :
Enjoy the Journey
.... Kev...
Old 05-31-2021, 09:29 PM
Top Jimmy's Avatar
The pull down menu where it says “Last Used”. Click on it and you’ll find “Stereo Mix” and others. You’ll also find any you made. How do you make and save your I/O settings file? Right in the I/O Settings window.
James Cadwallader
Old 06-01-2021, 05:36 AM
K Roche's Avatar
OK I found it Dashboard > I/O Settings > Last Used (I had never opened it) It appears to open a blank session ? Is that because I have my default format as Stereo ?
As for how I make and save I/O
When I launch PT I get this screen, I make my selection for which template I want,, type a new name and click,,,,, done
System :
Enjoy the Journey
.... Kev...
Old 06-01-2021, 07:39 AM
Top Jimmy's Avatar
OK we are still not communicating What pull down menu? located where? what are the actual steps
Right there under the sample rate. I/O Settings: Last Used. Click on it.
Once you have a session open, you can customize your I/O settings in I/O Setup, save it as a settings file, and then start with it every time you create a new session.
James Cadwallader
Old 06-01-2021, 09:16 AM
K Roche's Avatar
Yes thanks I finally found it and came back and edited my previous post
As I note I simply make custom I/Os, sends, plugins etc right in the mixer as for my session templates that are all done when I launch that template. Which I was offering the OP as a possible alternative to creating a new sessions and new tracks etc. every time
System :
Enjoy the Journey
.... Kev...
MIDI SETUP takes long to SETUP and doesnt SETUP DartagnanSosa87 MIDI 3 01-28-2013 12:02 PM
I/0 setup weirdness, sessions overwrite my setup digidesigner Pro Tools TDM Systems (Win) 0 10-20-2011 11:40 AM
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
I/O setup doesn't reflect my hardware setup devapro Pro Tools TDM Systems (Mac) 7 12-30-2006 11:16 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
