Old 01-27-2009, 11:48 AM
Class-A Class-A is offline
Question change volume fader after automated...
Hello,
Is there a way to change the whole automation volume track after it has been set up?
I.E. I have a rack tom that has been set up with volume automation, each drum hit is shaped and pulled down between hits...(acting like a gate)
Can I raise the level of the whole track with a short cut?
I like the automation fader moves of the rack tom, but I would like to increase the fader level over the whole track. Can this be done with a short cut keyboard mouse move?
Am I making any sense?
Part two: :)
Is there a way to raise an automated volume fader level between two points with one move with out having to click on each point. (I could do this with Mackie HDR using the shift key.)
Thanks!!
Old 01-27-2009, 11:57 AM
TOM@METRO's Avatar
Default Re: change volume fader after automated...
Triple click on the track and use the ] tool, or insert any plugin that gives you level control.
Part 2, Create a range and use the same tool.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-27-2009, 12:10 PM
Talking Re: change volume fader after automated...
Ah!!! That's it!!!!!! So simple....So Cool...
Thanks a bunch!!
Old 01-27-2009, 12:40 PM
Shan's Avatar
Shan Shan is offline
Unfortunately the above messes with the last Automation break point which could have audio past it so be careful with that one.
A faster & more accurate way without messing up the last break point, selecting the whole track, or inserting the Trim plug-in, is to place the trim tool past the very last break point or region. What ever comes last is where you place the Trim tool past that point. No need for any selection and it makes for a pretty fast workflow.
Hope that helps.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 01-27-2009, 01:36 PM
shtik shtik is offline
Shane that's awsome!!
I always use the trim plugin if I need last minute changes of whole tracks after automation. When I tried the obvious , that is selecting the whole region and trimming up and down, everything changed in the middle but the start and end points stayed where they were, making a transition between them and the next break point instead of just changing the whole range at the same amount.
Someone showed me both options when I was first learning PT a few years ago.. Then I forgot how to do it and gave up on it ever since. Thanks for bringing it back to me. Now I am not going to forget:)
Old 01-27-2009, 02:40 PM
TOM@METRO's Avatar
Hope that helps.
Shane
Thanks. Years of this and I've never done it that way, But I like it.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 01-27-2009, 07:50 PM
bblue bblue is offline
+1 definitely!
--Bill
Asus P6T DLX, Intel i7-920 OC'd to 3.2GHz, 6GB DDR3-1600 (triple), Win XP Pro SP3, PTLE 8cs2, MPTK2, Black Lion 003R, UAD-2 Duo, UA 2192
Monitoring: 24-bit dig to Avocet Crane Song controller, Pass Labs x250.5 amp, B&K N801 monitors, Transparent Audio analog cabling
Old 01-27-2009, 09:00 PM
That was my first suggestion as well but you could also open any plugin that is already on the track and adjust its output level(if it has one like all the EQ plugins have). I use both techniques without a preference for either.
Why is my fader stuck and I cant get it to change the volume in the mix? RuffinMedia macOS 5 02-22-2012 02:22 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
why is my fader stuck and i cant get it to change the volume in the mix? Jahlal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-06-2010 06:58 PM
automated volume question ssd Tips & Tricks 8 09-08-2002 08:46 PM
Pre/Post fader aux sends not automated?!? DannyVanSpreuwel Pro Tools TDM Systems (Mac) 2 11-29-2000 10:45 AM
