C25 ethernet noise?
Anybody getting noise using -10 devices or keyboards thru the focusrite inputs?when I use keyboards thru my line in mic pre's I can hear all the automation's movement ticking thru the speakers. Help?
Re: C25 ethernet noise?
Same problem... Just hooked the C24 up today. Tested it and noticed clicking sounds that increase in frequency when moving the faders while listening to mic/line inputs. Didn't get very far isolating problem. I'll post again if I'm able to find a solution. Help!!!!
Have you tried combine 'cold'and 'shield' of line output connector(Keyboard)?
Tell me the results. Thanks. |
On several cases in which noise has been detected when ethernet activity
(faders, VUmeters, etc) the solution has been to double check grounds on every connector. This includes the amplifier audio cables, and speaker cables. If this connection is not balanced, then the "-" has to be grounded. On other cases, when the power amplifiers and the Control 24 are plugged into different power outlets, this will result in a constant hum or buzz. Disconnecting the ground pin at one end of the audio cable feeding each power amp should break the loop. Similarly, if you are connecting a syntheziser or a guitar on the "DI" input with a mono cable, make sure you are using an unbalanced mono cable. If you use a balanced stereo plug or "TRS" then the "-" pin will float and will pick up noise. Hope this helps you solve instalation problems. If problems persist find your local shaman for the "Mother Earth Dance" Mike down in Mexico city |
This is what the Digidesign tech support guys had to say, via email:
This problem can been traced to a possible ground loop through the Ethernet connector board. Luckily, there is an easy fix which may solve this problem. Here's what you need to do: -Remove the 2 jack screws on the 9 pin D connector next to the Ethernet jack (I think it's labeled "I/O"). -Remove the metal shell from the connector on the Ethernet cable that plugs into the C24 (It peels off pretty easily) -OR- -Simply purchase an unshielded Ethernet crossover cable from your local computer store (this is different from a standard RJ45 cable). Best regards, Digidesign Technical Support I'll let y'all know if it works! |
did it work???????? hmmm?????
yes it works.
Yes It Works great!
Which did you do? Remove screws, or remove the metal casing from the ethernet cable?
Removing the screws was all it took to solve the ethernet ground loop.
Artist Control / Ethernet Connection and Noise Problems | lberrios1962 | Artist Series | 8 | 05-04-2012 08:20 AM |
Attn: Drumkit from Hell experts: noise noise noise | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-30-2003 06:31 AM |
Ethernet again... | kmt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-02-2003 02:54 PM |
Mac Ethernet help?? | David Lawler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-14-2002 07:12 PM |
ethernet... | jwhartmann | Storage Subsystems | 1 | 05-13-1999 10:27 AM |
