Old 08-14-2007, 11:45 PM
koka koka is offline
Default TDM vs rtas processing?
Im in the mood to buy McDSP Emerald pack native 1400US. But just wonder are there any sound difference between TDM and rtas plugins. ML4000 especialy?
I try demos and was supprised with sound quality of these plugs.With zero latency ?How is it possible?
Old 08-15-2007, 06:36 PM
Phil Jeffers Phil Jeffers is offline
Default Re: TDM vs rtas processing?
The TDM mix engine should have higher fidelity with its 32Bit mix engine. The actual plug-in quality shouldn't be any different. I know this to be true for Waves and UAD plugs (Waves confirmed this to me). You may want to check with McDSP though.
Old 08-15-2007, 07:36 PM
CME CME is offline
TDM are for Pro Tools HD only and run on the process cards. RTAS can be used on both HD and LE/MP but run on the computers cpu. So unless you have PTHD you don't need/can't use the TDM plugs, which are usually more $. As far as differences in sound, I believe they are negligible if non existent in most instances, with the 24-bit vs. 32-bit operation being the biggest difference.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 08-15-2007, 07:37 PM
TDM uses a 48-bit integer mixer. ProTools LE uses 32-bit floating point.
Quad 2.5 G5, 4.5G RAM
RTAS vs TDM processing dtmprod Pro Tools TDM Systems (Mac) 0 02-14-2011 03:09 AM
Old vs. New Mac Pro Question (RTAS processing) digidub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-06-2011 11:26 PM
Rtas processing issue josh18t Pro Tools M-Powered (Mac) 0 08-01-2010 09:43 AM
VST/RTAS wrappers & processing delays idris Pro Tools TDM Systems (Mac) 2 09-21-2006 05:56 AM
Separate CPU for RTAS processing? donrey Pro Tools TDM Systems (Win) 3 07-11-2006 07:01 AM
