002 R S/PDIF Output not working
I'm not sure why, but I can't get my 002 to output signal from the S/PDIF. I just got a monitor controller and I want to send a digital signal to it and have the controller do the D to A, but there's no signal. i know it's not the controller b/c my 828mkII can send s/pdif fine. is there a configuration i'm missing, or is my 002 just broken?
i went in i/o setup and checked everything i knew how but no luck. however, i can use the s/pdif IN to sync external clock, so is it possible the input is fine and the output is burned? please help if you can. thanks Tab
_______________ 003R PTLE 8 Mac Pro "Nehalem" OS 10.6.5 Axiom 49 NI Komplete |
Re: 002 R S/PDIF Output not working
What are you sending to the S/PDIF output? Master fader?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
yes, i was sending the master fader to the A12/s/pdif1-2 out that is the default then i alternately tried to create another s/pdif output in the i/o menu when that wouldn't work. any thoughts?
nevermind, i figured it out that it was a limitation in the digi002 that i did not know about. here is the solution if anyone has the same problem http://www.digidesign.com/index.cfm?...0&itemid=17480
Thanks. I came from a 001 and didn't know you had to set mirroring with the 002. Good to know.
S/PDIF Output w/003 | jc335 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-03-2010 08:45 PM |
mbox2 pro s/pdif output | ronknights | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-28-2009 05:19 PM |
S/PDIF output and inserts quit working | crom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-30-2003 08:59 AM |
888 interface's s/pdif input doesn't like AMIII s/pdif output | jmark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-19-2001 01:03 PM |
Monitor Mode not working with S/PDIF output | MichaelK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-24-2000 03:34 PM |
