Re: Overlapping Wav files in a Single Track?
Whether or not you can get the results you want using this method, I don't know, but best follow your own advice. Try it. |
I just tried it, it didn't work. Oh well, I figured there was a way to have both play on top of each other, like some other DAW allow you to. That's alright, I'll have to figure something else out. Like suggested, I might have to bounce the two files to make them into one.
thanks to everyone for the help. If anyone knows of an easier way, let me know. |
it will work, i do it all the time, unfortunately it's not easy to explain in a forum. the outshape should be the open square with the corner in the top right. the link has to be "None" and the in shape is the open square with the corner in the top left. with these settings your tracks will overlap the way you want with no fade occuring. the selection you make in the edit window prior to calling up the cross fade window will determine how long they will overlap.
Netrag, you're awesome. I tried it again, it worked perfectly.
Thank you. |
Multiple files from region list to single audio track | ocdrummerguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-19-2011 02:21 PM |
Conver stereo track to SINGLE mono track | markolone | Pro Tools M-Powered (Win) | 1 | 07-30-2010 07:09 PM |
Ripping multi track CD's to a single track | Plastik909 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-04-2005 09:18 AM |
Drag multiple files on a single track??? | sand | Tips & Tricks | 4 | 08-20-2002 11:11 PM |
Bringing multiple files to a single track | sburgess | Pro Tools TDM Systems (Mac) | 14 | 11-28-2000 09:56 PM |
