limited buss choice available for key inputs [SOLVED]
I can't get all my busses to show up as selections on my compressor key inputs. I have many busses set up for reverbs, delays, submixes etc and then set up a separate buss to send my kick drum, or click, signal to key a compressor on my synths.
Only 8 stereo busses are showing up as available to choose as a key trigger but I have many more than 8 busses in use (yes, I know I can only choose a mono signal to trigger from, but that's beside the point) Is there a priority system of busses to choose as key input triggers?? .. can I only select from 8 busses?? .. and if so, how do I get my buss I have chosen as a trigger to show up as a choice in the key input menu?? Yes, I RTFM but can't find any reference to this limited choice anywhere. Yes, I also posted this in Pro Tools (Mac) but thought it might be a PT11 or AAX problem. Scratching my head .. am I missing something here??
iMac 27-inch late 2013 / i7 3.5Ghz / 16GB ram OS 10.10.5 .. PT 11.3.1 .. Antelope Orion Studio blame no-one .. expect nothing .. do something |
Re: limited buss choice available for key inputs
Hi, Do all your stereo busses also have mono sub paths? Don't think any busses which are stereo only are available as key inputs! Chris
that was it, problem solved!
thanks Chris
Re: limited buss choice available for key inputs [SOLVED]
Glad you got it sorted. For others, be aware that you can add buses to your list at any time(up to the max of 256 IIRC). Just open Setup>IO>bus tab and add paths(maybe add 12 mono and a few more stereo, just to be set for the future).
Aux buss path going to wrong buss? | [email protected] | macOS | 3 | 10-10-2013 08:50 AM |
Limited Mic inputs, looking to mic a kit | Hotcrazyfruit | The Drum Room | 14 | 10-06-2010 04:00 PM |
Output to a Buss or send to a buss | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-11-2009 04:28 AM |
SOLVED>>Need HELP, SUPER ASAP.< |
audioindo | Pro Tools TDM Systems (Mac) | 18 | 04-21-2007 05:43 AM |
