question about delay compensation
hello guys,
I purchased Ozone 5 plug-in today and now for the first time in my whole recording/pro tools experience, I'm seeing delay in my tracks. I hold cmd(mac user) and click on "vol" twice for each track and check delay, it's around 1400 1500 on master fader. So I enabled delay compensation and set it to "long" (says it's around 4000 samples). sound is fine, I sense no delay, no out-of-sync tracks, nothing. but my tracks still show the same amount of delay when I hold cmd again and check delay again (after I enable delay compensation). is it normal or something wrong? second question: do you guys think I should just select the "maximum" option for delay compensation, regardless of how much delay I'm getting? I mean, would be like just in case? thanks. |
Re: question about delay compensation
That's normal. Pro Tools doesn't remove plugin delay, it compensates for it. So you have to look at the CMP field to see what's actually being done to keep everything in line. If you activate "Delay Compensation" under your window view parameters, you will see all the delay engine parameters and you can leave the main "vol" field on "vol"!
Edit: Check this: http://protools.dudesnetwork.com/201...d-part-1-of-2/
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Delay Compensation Question | Roulette Records | Pro Tools HDX & HD Native Systems (Mac) | 14 | 10-13-2013 08:03 AM |
New guy question on Delay Compensation | PMcC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 07-25-2009 01:29 PM |
Delay compensation question... | AudioMaster | Post - Surround - Video | 5 | 02-24-2009 12:58 AM |
Delay Compensation Question | R-Blitz | Pro Tools TDM Systems (Mac) | 5 | 11-24-2005 09:30 AM |
Delay compensation question...? | coryc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 04-03-2005 12:52 PM |
