The Monsters Of High Gain
Premier Guitar put together 13 videos with 2 different players demonstrating the tone of 13 high gain amps. Check it out
http://www.premierguitar.com/Magazin...High_Gain.aspx You can use these to try to model the tones on the 11R if you are so inclined. If you dont already have a program to download Youtube style videos (.flv .f4v ect..) Donwload Realplayer for free, it comes with that ability. If you dont already have a program to pull audio from a video, Realplayer also comes with a free video converter that will pull out just the audio from a video so you can load the samples into PT. http://www.real.com/ Slap a Spectrum analyzer on there and start makin' some new presets.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Re: The Monsters Of High Gain
What! Aren't you going to do that for us . C'mon Benoni, you know you want to . You can make it my Christmas present. Oh, and thanks for the link, greatly appreciated. |
Thanks for sharing Benoni.
Thanks so much for the tips and links!
If they only could use some proper guitar players
Video demonstartions can be a double-edged sword. Some benefit your product, some don't. Anyway, thanks for sharing. |
The only amp that sounded any good through those videos was the Framus Cobra!!! I mean I've heard the Mesa, ENGL, Diamond and Diezel on other vid's on the Net and been completely blown away. Oh well, maybe I was expecting too much . |
They work for AVID, in the 11R departement
How do they make them sound so horrible? They scoop the mids for the "metal" sound. The problem with these hi-gain amps is that to me they all sound the same. The Cobra is the only one that sounds different. About two years ago I heard the "Hi-Gain Amp Shootout" on Soundclick and out of 30 different amps only about 4 amps stood out: the Diezel, 1976 Friedman modded Marshall JMP Mk II, Framus Cobra, and the SLO, and the only one I could take a steady diet of was the JMP. I'd also have liked to have heard the clean channels. You guys can easily do as well on the 11R.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
Who do you think I am, Benoni or something?
Eleven Rack and high gain | SloeGin | Eleven Rack | 17 | 09-11-2015 10:12 AM |
Can 11r do the high gain? | derker | Eleven Rack | 4 | 10-05-2012 01:03 PM |
MBox: Normal to need such high mic gain? | P_M_C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-06-2003 11:15 PM |
Recording high gain guitars with HD/192 i/o | superdood | Tips & Tricks | 11 | 02-11-2003 08:17 PM |
Good High gain Mic Pre for Royers | juneaudio | Tips & Tricks | 13 | 11-30-2000 08:16 PM |
