#21
Re: To bass manage or not to bass manage
wow, why do you think that i am confusing bass redirect with the LFE channel? i thought i explained the difference. apparently, i am not making myself clear, and it could be because i am tired. the mistake i described was made because i was not all that familiar with 5.1 ... why would you think it was a room dependent problem? i simply did not send anything to an LFE (channel) in my first mix (because i was hearing it being redirected and wasn't aware that theater would not re-direct). so nothing was in the LFE channel going into the SUB woofer when i went to the theater. had nothing to do with a room problem. it was operator ignorance, not a room issue. once i shut redirect off, it worked fine in my room and the theater. i have larger (down to 35Hz) fronts...(genelec 1032) not quite full range...and a small 22Wx15.5Dx11H room. i have cal'd my 192, RTA'd my ROOM and Pinked Monitor path (with an RTA & SPL). it is all good, spot on. so i don't use bass re-direct unless i am doing a DVD mix, or checking for bumps. and my mixes translate fine to a dub stage and theater. my broadcast mixes also translate fine. but apparently, my writing does not. that said, are you suggesting that i should be using bass redirect?
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
#22
fwiw I wrote an article for MIX mag on bass management and the use of LFE material. It's about 2 years ago.. I'll try to dig it up for you guys.
cheers geo
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
#23
Hey Tom,
Isn't this fun?!!! At the risk of totally pissing you off, I might suggest that your system might be miscalibrated. Before you start teeing up balls and whacking them my way, hear me out. One of our first 5.1 projects was for the Omni Theater. Our room was "spot on" also. But when we played a test mix in the theater - the low end was way off (I can't remember which way - but it was embarassing). So I consumed everything Tomlinson Holman wrote and all the pdfs on the Dolby website. To make a long story short, I somehow had managed to flatten my room, but have the sub set up wrong. Since fixing that, our mixes have translated very well in theaters (so far). Our room is small too, but if your room is free of nasty low-end resonances and your system is calibrated properly, I can't think of any good reason why you're mix would sound "big and boomy" in your room (regardless of how you directed the bass) and not sound close in the theater. That being said, I think sending the rocket to the LFE is appropriate simply for headroom reasons. Afterall, the only reason the "boom track" even exists is to buy 10 more dB of headroom in the track. If my thinking is on here (and I'm sure someone will correct me if its not), if it weren't for headroom issues, we probably wouldn't have an LFE track. We'd all just send as much boom as we needed into the main channels and we'd have crossovers in the theater to route the lowest stuff to the sub. It's also possible the theater you played back in was out of cal (I've seen that before). In the end, our bass management will be staying on - whether it's for DVD or theater. You may have more options with the 1032's. Goodnight. Brad |
#24
With regard to how a mix sounds on a bass-managed system, as compared to a non-bass-managed system: If the bass-managed system is calibrated correctly, and the speakers that you are comparing the system to are also full-range, then it should be very similar and translate well (room acoustics and other 'things' all being relatively equal). If your mix sounds bass heavy in the smaller room, that could be because of room modes & other acoustic issues (sub placement etc), and / or there could be an issue with regard to calibration. Conversely, there could also be problems with the playback system in theater you are comparing it to, such as not having good LF extension. In general, our users have told us that they have had a great deal of successes taking a mix that was created on our bass-managed systems and then moving it to a dub-stage / movie theater. I hope that helps... Cheers!
Pascal Sijen Independent Technology & Marketing Consultant Co-Founder Blue Sky International & Audio Design Labs Inc. |
#25
Not to keep beating on the dead horse, but in response to why I said that here are some of your statements that confused me...
This is why I thought it may be a product of the room. If you hear the low end on your non full range speakers, it should be also be there on the theatres full range speakers, regardless of what is or isn't on the LFE track. Quote:
Eric Lalicata C.A.S. Supervising Sound Editor Re-Recording Mixer Anarchy Post 1811 Victory Blvd Glendale, CA 91201 818-334-3300 www.anarchypost.net |
#26
morning fellas.
ok. i get it now. i can see how you would be confused by some of my posts. i wasn't as confused as you thought, but i see where i was wrong. i was wrong to suggest that bass re-direct be defeated in a system that needs it, even though i don't use it when it is not needed -- and i wasn't clear about that advice. i am clear now about how a system such as blue sky would handle the LFE channel. (i am sure that the mixes translate, otherwise, people wouldn't use them. i certainly wasn't criticizing this system or any other system like it.) hopefully my muddling helped someone be clear about a few things here. a question about that. in a bass-redirected system such as a blue sky, where is the information from the LFE channel that is above 80Hz? in the the SUB or the satellites? i would think it would have to be distributed. did i just answer my own question? that was what my question was in one of my posts that i am still curious about. the reason that i had a problem with that mix, i found out, was that their system did not have full range fronts, nor, were their crossovers setup right. the mains had a rolloff starting at 50Hz, so all that stuff at 40 was disappearing. when i remixed putting information in the LFE channel (where it wasn't before) then the mix sounded fine in their room. thing was, both versions, bass re-directed (no LFE info) and bass not re-directed (LFE info) sounded fine to me in my room. brad, thanks for the suggestion. yeah, early on, it is confusing on how to set things up when you haven't done it before and you are getting info out of books and articles rather than having a trained technician show you how to set it up. i did it once. and then i did again. cause it wasn't right. when i made some changes in the winter, i checked it again. with bass re-direct on and with it off. it is fine. this was the only time i had this problem, and as i said, i just found out it was their room. i have heard my mixes in several different venues and mix rooms, and they translate as i expect.
#27
Brad McIlvaine
Brad McIlvaine Sr. Mixer/Designer Henninger Media Services Washington, DC 20036 |
#28
Here is a link to a signal flow diagram that shows how our BMC works. www.audiodesignlabs.com/signal1.jpg Cheers!
#29
It's a whole bass management/LFE seminar in one thread! I'm going to print this thing out for future reference. (Hope I have enough paper).
Brad over and out |
#30
The block diagram helped me understand the Blue Sky system. Thanks for that.
Now, in most systems (bass managed or not), where is the low pass filter (for the LFE channel) in the chain. Does it vary from system to system or is the filtering done on the actual program material before it leaves the dubbing stage? From the looks of the blue sky diagram, you can choose whether or not you want to use the 24db / oct 120Hz Low Pass filter. Is this filter built in to the system?
Rick Sanchez http://www.posthastemedia.com MacPro 2x2.66 GHz Dual Core "WoodCrest" Mac OSX 10.5.8 / 4 Gig Ram ProTools 8.0.4 Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro) HD3 Accel BlackMagic Decklink Studio 2 (In Slot 3 of MacPro) SurCode / Dolby Media Meter 2 Izotope RX2 Advanced / Sonic NoNoise Waves Platinum 7.x / Serato PitchnTime Melodyne Studio / Altiverb XL / Speakerphone KOMPLETE 7 EQuality / Massey L2007 TC MasterX |
PT 8 Manage plugins | jerberson12 | Pro Tools TDM Systems (Win) | 2 | 11-09-2011 11:16 PM |
manage beat and tempo | drasmith | Windows | 3 | 09-17-2011 03:32 PM |
Please Weigh In: To Bass Manage or Not To Bass Manage, that is the question. | Wyn | Post - Surround - Video | 10 | 08-06-2011 08:42 AM |
How do you manage Pluggos in AudioSuite?? | curve666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-08-2004 12:43 PM |
How to best manage tracks in LE | Steel City | Tips & Tricks | 7 | 10-16-2003 09:05 PM |
