Stereo/Surround Mixer on Install
Doh! I forgot to click on the stereo option when installing 7.3 and instead have the surround sound mixer installed.
What is the best way to get back to a regular stereo set up? thanks peeps Sam
Pro Tools 12.8.3 iMac 4 GHz Intel Core i7 OS 10.15.7 24GB RAM UAD Satellite Quad UAD Apollo Twin |
Re: Stereo/Surround Mixer on Install
just go to your plug in folder and pull the surround mixer into the plugin unused folder, then pull the stereo mixer from unused plugs to the normal plugin folder. Obviously though, make sure pro tools isn't running when you do it.
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
many thanks.....that sounds cool - I don't have to deinstall then install again with the right box ticked? Does this mixer install option only effect whether the surround plug gets installed then?
cheers Sam
unless I'm mistaken, it affects that plug and a few preferences. The preferences are easily editable though. If you want (and find it easier), you could just reinstall and select the correct box, but its not really required to correct the mistake.
many thanks man! I changed the plugs and all is good! If anyone knows the prefs I should trash just to keep things smooth, please lemme know what they are.....
How to deal with Latency from Surround Mixer - Stereo Mixer. | Spyderrp7 | Pro Tools TDM Systems (Mac) | 9 | 11-02-2012 03:41 PM |
Installer WANTED:Neyrinck SoundCode Stereo surround-to-stereo down-mixer | Ale | Pro Tools 10 | 3 | 08-14-2012 09:05 AM |
Adding Surround mixer after install | RandyG | Pro Tools TDM Systems (Win) | 2 | 12-15-2006 09:59 PM |
Creating new stereo track in surround mixer | Keith Leary | Post - Surround - Video | 0 | 10-19-2004 04:13 AM |
Surround mixer taking up three chips in a stereo session!! | el biciclista | Pro Tools TDM Systems (Mac) | 6 | 03-31-2003 01:42 PM |
