Old 02-11-2015, 02:14 AM
idris idris is offline
Default EQ automation and processing delay
(Sorry if this has been asked before - I can't find an answer and it's been bugging me for years. Literally.)
When automating EQs (pos other plugins too, but less noticeably), if I have a jump in a parameter right at the start of a clip eg switching in HPF or a change in freq, I invariably get an audible glitch as the plugin seems to sweep to the correct settings. It only takes a tiny fraction of a second but it's enough to be a problem.
My work around is to make sure all parameters are at the correct point a second or so before the start of the appropriate clip. Not a problem, unless I move a clip from one track to another, and forget to double check.
I've got delay compensation switched on (which seems the logical solution) but is there a way to prevent this behavior?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 02-11-2015, 03:03 AM
Default Re: EQ automation and processing delay
That's because automation isn't sample accurate in PT10 and older so depending on your session load all automation incl. volume can lag behind. In the old days we even had to move volume graphed de-essing earlier than the actual S to manually compensate for lagging automation.
In 11 it is sample accurate (to enable offline bounce) but some plugins still have a certain reaction time so you still have to do what you're doing. It's way better in 11 and you rarely get these audible sweeps but sometimes you still do.
Having said that, I also wish there was some kind of auto-extend all breakpoints by 10 frames beyond clip margins or something like that which automatically keeps a certain "safety zone" around clips.
Frank.
Old 02-11-2015, 03:28 AM
B******! I thought that might be the case. Never mind. Thanks anyway Frank.
Old 02-17-2015, 08:21 AM
jahtao jahtao is offline
I'm still seeing this problem in PT11.
It happens with the fader and not just plugin automation. Pretty lame.
Can anyone point me to a document that explains if / how it's fixed in PT11. I don't think it is!
Matt : )
HTML code is On
Is Automation delay compensated via ADC? made Pro Tools TDM Systems (Mac) 4 04-11-2010 03:19 AM
Automation points follow processing? wazzat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-09-2009 01:36 PM
RTAS processing delay with Expansion chassis colinweeks Pro Tools TDM Systems (Mac) 10 11-09-2007 12:29 PM
Cedar DNS2000 Processing Delay colinweeks Post - Surround - Video 0 07-31-2007 09:56 AM
fx/processing delay? fasttraxx Tips & Tricks 4 10-03-2001 02:49 PM
