  #61
Old 01-29-2025, 02:49 PM
Default Re: Error -20021
Suspend auto doesn't fix it. The ONLY reliable way to get around it is a restart except sometimes thin all across certain areas of the session and documented years ago in this thread.
I have tried this and other things countless times. Should all be documented in my support case
Case : 03774787
PTHDnPCIe 2025.6 (OSX15.5), Eucon 25.6, 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
  #62
Old 02-05-2025, 03:24 AM
o-matic o-matic is offline
Hello everyone,
I never had this problem before installing 2024.10.
I'm working on a short film but with a lot of tracks. The automation is not particularly dense compared to other projects.
I'm going to reinstall 2024.3 and hope for the best...
  #63
Old 04-16-2025, 09:56 AM
zzzele zzzele is offline
When the Error -20021 appear and I suspend all automation in automation window, playback is restored. I can work then, but as soon as I enable all automation, error is back. PT restart is only solution that I could find. Preferences delete with PT Prefs 2 doesn't help.
  #64
Old 04-27-2025, 06:16 AM
Another observation. Whenever you have an active input going AUX or rec track set to input from either AUX I/O or a physical input or virtual in (like DVS) try turning that off. I get increased 20021 errors whenever I have to have a track in input mode coming from something that is not an internal bus.
This is obviously not always possible but it helps to turn off any physical ins into your session to at least minimize 20021 errors.
But since AVID said that they have this issue fixed in 2025.6 I hope the days are numbered. Another month of 20021 is just about as much as I can take after 7 years of this issue.
  #65
Old Yesterday, 11:27 AM
Gregor B. Gregor B. is offline
Think you might be onto something here, Frank.
Just had this error for the first time (2024.10.2) and had one of those AUX I/O virtual ins open...
  #66
Old Yesterday, 02:13 PM
marianna's Avatar
marianna marianna is offline
Frank....
I thought you were on 2025.6??? your specs indicate 2025.6 but if you arent on that, I need to know what you are on?
I just created a case and referenced all the cases you had with the -20021 error and your recent hint.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #67
Old Today, 02:08 AM
Originally Posted by marianna View Post
Frank....
Marianna
I was on 24.10.2 when I posted that back in April (as 25.6 was not yet released) and co-workers said they also got way less errors by de-activating any aux i/o inputs back then (obviously this is not always possible). So far I have not had the error since going to 25.6 but I haven't done extensive work with it. That said the 22005 and 22006 errors are still happening (release notes said they were fixed in 25.6 and 24.10.2) but those can be worked around by de-activating/re-activating the video track so don't require a full system relaunch. They are less disruptive.
Frank
HTML code is On
AAE - 20021 was encountered? Cheesehead Post - Surround - Video 7 11-07-2020 11:51 AM
AAE Error -20021 DonaldM Pro Tools 12 5 09-07-2017 07:01 PM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
