Old 01-02-2011, 07:01 PM
Kenmillerjr's Avatar
Kenmillerjr Kenmillerjr is offline
Default iTunes through HDx
Is it possible to route the audio playback from iTunes to the VENUE through the HDx assignables?
Ken Miller, Jr.
Audio Engineer
Southside Baptist Church | Warner Robins, GA
| VENUE Profile 96X64 with MADI Option | ProTools 7.4.2 HD3 Accel PCI | ProTools 10 Native | MacBook Pro 17" OS 10.7.1 2.3GHz Intel Core i7 8GB Ram | Mbox 2 Pro | Mbox 3 Pro | Motu 896mk3 Hybrid |
Old 01-03-2011, 03:20 AM
Chris Johnson Chris Johnson is offline
Default Re: iTunes through HDx
I don't see why not, provided you have ASIO or CoreAudio drivers for the HDx interface (which i'm guessing would be the same as the drivers for 192 IO). But remember, once you open PT, it takes over control of the PT hardware meaning you can no longer use it in any other mode.
Old 01-03-2011, 07:31 AM
So, the CoreAudio drivers are not installed with the installation of ProTools? I'm guessing those can be taken from AVID's site?
Ken Miller, Jr.
Audio Engineer
Old 01-03-2011, 09:29 AM
Excellent question - they are in the case of PTLE - i've never checked with Protools HD, but logic would follow that they are.
Simple way to check is to quit protools, go to System Preferences > Sound, and see if your HDx appears as an output?
However, i'm not sure how clever the drivers are - to be honest, they may just output on channels 1 & 2 unless you are using some other software which can address the channels individually.
Old 01-03-2011, 10:36 AM
Nicolas Lowman Nicolas Lowman is offline
Hi Ken,
So I just tried this on a HD system with 192 i/o. I played a CD from iTunes on the HD computer through the 192 i/o. Under system preferences/sound/output, Digidesign HW is listed. After selecting Digidesign as the output, when I load iTunes a Digi Core Audio Manager application loads as well. It then outputs the CD audio to my monitors that are patched to the 192 i/o. However I can't load Protools while the Digi Core Audio application is running. So you can use it to playback back from iTunes only while Protools is not running. They don't like to share the interface.
Nicolas
Old 01-03-2011, 11:11 AM
Awesome! Thank you very much for looking into this!
Ken Miller, Jr.
Audio Engineer
Old 01-04-2011, 05:00 AM
The question is - did you get to select which outputs of the HD interface the iTunes returned via? because obviously its gotta end up in the HDx assignables (49-64) to be of any real use...
MP3 vs. iTunes MP3? SDDP Pro Tools TDM Systems (Mac) 1 11-24-2010 06:57 AM
ITunes question: Can ITunes convert wav. to mp3? GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-22-2010 02:32 PM
PT 8 and iTunes 8.x ladyback Pro Tools TDM Systems (Mac) 1 03-15-2009 07:24 PM
Problemas Itunes! / Problems Itunes-Mbox MEPHISTOX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-29-2008 05:37 AM
OT.....iTunes Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-31-2003 04:12 PM
