Old 11-05-2008, 01:58 PM
DWAGS1 DWAGS1 is offline
Default ASIO Driver for WAVELAB???
when i ran my 002/7.1 Wavlab was able to use rack for audio
now
003/7.4 wavlab can't find driver?
what am i missing?
Digi 003R * PTLE 8.0 +AMD Dual Core * 4GB Ram
and a dream....................
My Studio
http://www.bleedstreetstudio.com
Old 11-05-2008, 03:12 PM
shea shea is offline
Default Re: ASIO Driver for WAVELAB???
now
what am i missing?
what os are you on xp oe vista or mac
seamus
Old 11-05-2008, 03:14 PM
Are you on XP or Vista? In XP it shows up in my WaveLab preferences. I choose not to use it though as I run the optical out of my motherboard to the optical SPDIF in on a Presonus Central Station. Previously, I ran a cable from the mini out of the mobo soundcard to the AUX inputs on the 003. That way I never have a hardware conflict. Vista has no working ASIO AFAIK so the cable is the only way.
Old 11-05-2008, 03:25 PM
seamus
XP
My Studio
Old 11-05-2008, 03:29 PM
The digi asio shows up under my preference/audio card in wavelab
i select it and it seems fine
but when i hit play i get the
error
1. wrong sample/bit rate....(not that)
2. the device is being used by another app (not that)
3 wavlab does not recogonize the device (???)
like i said it worked fine with xp/002 rack
My Studio
Old 11-05-2008, 03:32 PM
is there a asio driver disc i should have gotten with 7.4?
My Studio
Old 11-05-2008, 03:33 PM
Hope you dont mind me correcting you digi asio works great in vista as long as you give it permission.
seamus
Old 11-05-2008, 03:38 PM
XP
There is no reason why this shouldnt work in xp if you have it set up correct in prefs
asio is a single client driver so can only have one sterio out sellected
Hope that helps
seamus
Old 11-05-2008, 03:57 PM
JMS40 JMS40 is offline
Just for clarity... There is no Vista WAVE driver but there IS a Vista ASIO driver.
And, yes it is single client (only one program at a time) but you are not confined to one stereo out. The ASIO driver can utilize all the multiple I/O's of your Digi device.
Dwags1... the ASIO driver should have been installed along with 7.4. To make sure, go to Add or Remove Programs and choose to Modify your Pro Tools installation. Make sure ASIO is checked off as an option... don't Un-check any of the other options or they will be un-installed.
Once you are sure the ASIO driver is installed, it should be available inside the audio preferences of any ASIO compliant program.
Good luck-
Old 11-05-2008, 04:05 PM
Good luck-
I would not aegue that point depending on which programe you use
seamus
MBox, Wavelab 4.01 and ASIO Driver Problem GroovehouseRS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-17-2005 11:56 AM
An ASIO Driver that works with Wavelab PedMar Pro Tools TDM Systems (Win) 5 03-30-2004 10:17 AM
ASIO driver, 001 & WaveLab efernan1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-13-2003 04:35 PM
001 ASIO Driver and Wavelab DaveJDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-04-2003 08:10 AM
Digi001 with ASIO driver on Wavelab 4 Nahvegador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-22-2003 11:14 PM
