AAF vs EdiLoad and conforming from rushes
I'm thinking about getting EdiLoad to start doing dialogue builds from EDLs rather than trying to get working AAFs with all the production sound metadata still intact.
I would say that on 90% of jobs I have issues with AAF turnovers and often quite a bit of back and forth to get what I need from picture departments and I still don't always get AAFs that have all the scene / take / channel name metadata intact in the production sound. So my questions are: Is getting an EDL which works in EdiLoad easy? Do you have to be very specific with what you request or will any EDL that contains all location audio tracks work? (I know about the 4 track limit in EDLs so am anticipating having to ask for more than one EDL.) Does it still work when dealing with production sound that has had some or all of its metadata damaged or stripped? E.G. when projects come through Premiere. I also really like the look of the scene change and picture cut tracks features in EdiLoad, would love to get that task automated, especially for feature work. Would be good to know if that's a reliable feature and if it requires any specific requests when asking for EDLs. Thanks for your help!
PT Ultimate 2021.3 | macOS 10.15.7 | Mac Pro 7,1 michaelfbates.com imdb.com/name/nm4876413 |
Re: AAF vs EdiLoad and conforming from rushes
Too many picture editors these days have ever done a 3 machine online and do not speak EDL. But don't let that stop you trying.
When you find co-operative assistants it can be a joy. I would never mix a drama without scene change tracks, even if I have to do it manually. Sent from my iPad using Tapatalk
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
Yep, I already do scene change tracks manually, just interested to hear if EdiLoad actually manages to automate it reliably.
Hi Michael,
Thanks for checking out EdiLoad It should be, but this depends on your editor or assistant editor Quote:
For more information on conforms (assembling WAV files) with EdiLoad and Pro Tools, see the videos in the following two blog posts: Conforming (assembling) Location WAV Files with EdiLoad and Pro Tools Customising an Edit List to Conform location WAV files using EdiLoad Quote:
Feel free to download EdiLoad and try it out for yourself. Simply click the 'Try' button when you first run it. Regards, Mark
Mark Franken, MPSE Dialogue editor/supervisor IMDb Creator of 'EDI' applications for sound post editors www.soundsinsync.com |
I'm a big fan of EdiLoad. Getting useable EDL's has usually been no problem. Sometimes I have to clean up and/or transfer roll names between columns, but EdiLoad is pretty intuitive in that regard.
I've only run into one major situation where the I had metadata issues on the EDL and it was because an Adobe editor was using merged clips in their workflow, which was nesting the audio clips in what the EDL read as video clips. It took some convincing on my part, but I got the editor to rebuild his audio on the timeline which enabled the EDL export to include the metadata I needed. One thing I like to do with the scene change track is add in scene descriptions and use the track for my EdiCue ADR exports. I'll copy/paste the descriptions from a continuity list if one exists or make a simplified version from opening the script in the session interface in EdiCue and send the scene list info to the clips in Pro Tools. -Justin
Justin Walker |
Mark, that's amazing, thank you so much for this reply! It's so helpful, I'm planning to test EdiLoad on my next show, really looking forward to using it.
Ediload sound conforming (Sound rushes) | Soundburst | Post - Surround - Video | 2 | 01-29-2016 06:39 AM |
link to the original sound rushes when editing in Media Composer | guyfixsen | Post - Surround - Video | 2 | 04-24-2015 01:07 AM |
EdiLoad v3 released | mfranken | Post - Surround - Video | 2 | 03-09-2015 09:27 AM |
Sounds In Sync releases EdiLoad version 2 | mfranken | Post - Surround - Video | 0 | 04-20-2012 07:21 PM |
Syncing multichannel rushes | Peter Groom | Pro Tools TDM Systems (Mac) | 3 | 05-14-2010 12:31 PM |
