#21
Re: Why
These days I only buy music that has been recorded with 32 bit floating.......or partially submerged............point RTAS plugs.
I like a fluid tone.....and I know what I like. |
#22
Re: Why
There is no difference. TDM and RTAS versions of the same plug-in will cancel when doing a null test.
#23
Re: Why
I've tried macs, PCs, Commodores all to no avail! It is making a rather nice artificial home for my yabbies though. |
#24
Re: Why
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#25
Re: Why
Let me say just one thing..........Vic 20. I mean if you want to talk about floating points. I fear I've said to much. |
#26
Re: Why
you should be *WORKING* Phil!!! ;-)
On that note... you guys should read Stephen Massey's take on it (the guy behind Massey plugins)... here's a link to his blog regarding the whole RTAS vs TDM debate. http://www.smassey.com/blog.html#28_apr_2009 As for inconsistencies... try buying 2 of the same vintage analog processors and see if you can tell the difference... Back then, EVERY bit of gear was different, even if it had the same faceplate!! I have an analog console... and i *KNOW* there are some channels that sound totally different to other channels, even though they are labelled the same. It forces you to FIND WHAT WORKS.... It's all part of the fun of making music. The point is, if we are so hung up on whether the RTAS version sounds different to the TDM version, somewhere along the way we've either 1) lost the pursuit of making good sounding music with WHATEVER tools are available, or 2) bored / don't have enough work to keep us from getting hung up on little things like that. Hope you can take a moment to rediscover the fun side of making music, or whatever you do Henry
Pro Tools HDX // 11.3.1 HD // 2x Avid 16x16 HD I/O // 2x 192 I/O // Avid Artist Mix 2012 Mac Pro 12-core // 64Gb RAM // macOS 10.12.1 SSL 4056G |
#27
Re: Why
i have nothing to say to this gentleman at this time
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
#28
Re: Why
I personally don't care if its RTAS, TDM, HPV, HIV, VST, DAT, TAD, MAS, SAM, UA, AU..... if it sounds good, it IS good!
AKA - EvilElfHobo Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4 Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified. Multi-Platinum Pro Tools Videos |
#29
Re: Why
Whoops I forgot STD. LOL
#30
Re: Why
Bounce some tracks with same settings rtas/tdm, and do null test. Report back. I hear a difference between the processing on my gold plated PCIe cards over my normal stock digi ones. But I haz no proof!
This is easy to test. So go do it, or shush. |
